loss of power, HELP - JeepForum.com
post #1 of 11 Old 07-06-2004, 10:09 PM Thread Starter
puch1313
Guest
loss of power, HELP
my XJ just started doing this last night.... every once and a bit, ususally after a turn, or coming off a stop light, the car totally looses power, so i put the pedal to the floor and after a second of dogging around, it redlines and its smooth sailing from there on out. also, today it has been occasionally idoling xtreamly rough at stop lights, but not often. i have no clue what this could be....the only thing i have done to the car recently is installed a k&n filter in my stock air box....and i dont see how that would be the cause of my problem......help!!!
thanks
Pat
puch1313 is offline
post #2 of 11 Old 07-06-2004, 10:33 PM
cfkingfish
Guest
You may want to start with a tuneup, if it hasnt already gotten one. Cap, rotor, plugs, wires, the whole nine yards. Check for spark in the coil, and check to make sure the fuel pressure is normal. It could also be your crank sensor. Unfortunately a rough idle and cutoff could be most anything, any other symptoms?
cfkingfish is offline
post #3 of 11 Old 07-08-2004, 10:42 AM Thread Starter
puch1313
Guest
nope, there really arent any other symptoms...my gas guage recently clunked out on me, so maybe the fuel system is starting to bug up? i purchased the car in march...and i was told by the previous owner that plugs/wires/etc were done about 5000 miles prior to my purchase, i guess he could have been lying, but for som thing that small, i dont really think so......i guess i may have to break down and take it to a jeep dealer
puch1313 is offline
post #4 of 11 Old 07-08-2004, 11:09 AM
mbood82
mbood82's Avatar
Could probably be the fuel pump.... that seems to be the culprit with alot of it.
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
mbood82 is offline
post #5 of 11 Old 07-09-2004, 12:41 PM
osudelt69
osudelt69's Avatar
I had a small tiny fuel leak on the hose coming out of my fuel filter. Fixed the hose and replaced the fuel filter and it quit bogging down
1997 TJ. 2.5L 161k and counting. Skyjacker hydro shocks. 30x9.5 Dayton Timberline AT. Bestop RAT and Prop Top
osudelt69 is offline
post #6 of 11 Old 07-09-2004, 01:05 PM
bdhaley
Guest
I have having the same exact problem that you are. Maybe these guys will shed some light. I am gonna replace the fuel filter before I do anything else.
bdhaley is offline
post #7 of 11 Old 07-09-2004, 06:32 PM
james harmon
james harmon's Avatar
This is not just BS, it is experience talking, so listen up.
Put a fuel pressure gauge on it at the valve on fuel rail. Should be over 30psi. If not, trouble shoot fuel problem.
If you got any plugs other than the cheap Champion, (like platinum tips) get rid of them and install Champions. Then cap rotor and wires if necessary. Don't have to get fancy with the wire either, it is a waste of money.
I just got through with exactly what you are living now........
james
www.geocities.com/jammerjamesharmon
90 Larado, 5" lift, 35" MTR's, HP/D44/ARB/488, D30/Superior axles/ARB/488, Clayton Long Arms, Revolver shackles, WJ front brakes, knuckles. linkage & master cylinder/booster, ZJ rear disk brakes, Warn XD9000, etc, etc, etc........
james harmon is offline
post #8 of 11 Old 07-09-2004, 10:53 PM
mrknocke
Guest
Originally Posted by james harmon
If you got any plugs other than the cheap Champion, (like platinum tips) get rid of them and install Champions. www.geocities.com/jammerjamesharmon
whats the knock on platinum tips?? just curious cuz i installed some bosch platinums on mine and have been happy w/ them
mrknocke is offline
post #9 of 11 Old 07-10-2004, 12:07 AM
james harmon
They are for newer cars with the hotter spark, that have coils for each cylinder and mounted close to the plug. Older designs, like my 90, the spark is not hot enough to keep that tiny little platinum tip clean. Just a little crud and it is fouled. They will work for a while and then...........misfire...........
james
post #10 of 11 Old 07-10-2004, 08:57 AM Thread Starter
puch1313
Guest
i suppose that makes sense, ive never herd of that happeneing before....I really need to figure this one out. yesterday i got in my car after work, didnt touch a thing, just turned the key, and all of a sudden my RPM's go to like 4000 then drop right back down. it was like my xj was possessed!
puch1313 is offline
post #11 of 11 Old 07-10-2004, 09:21 AM
BADCJ5ERS
Guest
Up & Down Idle
HI SOUNDS LIKE YOU MAY HAVE A THROTTLE POSITION SENSOR GOING BAD. ITS MOUNTED ON THE END OF THROTTLEBODY SHAFT. HOPE THIS HELPS BADCJ5ERS
[email protected]
97 CHEROKEE 4.0
K & N MSD COIL MSD 5200 IGNITION PAC.
1959 CJ/5 245 HP. 70 JEEP V/6
GROUND UP RESTORE
BADCJ5ERS is offline
Power loss TravisE XJ Cherokee Technical Forum 6 01-13-2011 10:35 PM
loss of power v1persrt10 XJ Cherokee Technical Forum 1 11-09-2009 07:52 AM
loss of power skferreri XJ Cherokee Technical Forum 0 03-08-2009 06:14 PM
Loss of Power in 4HI OnlyinmyJeep XJ Cherokee Technical Forum 1 07-28-2004 02:52 PM
Loss of power.. JUNIOR80 XJ Cherokee Technical Forum 10 03-03-2002 10:06 PM
