Loose Rear End in the Rain - JeepForum.com
 6Likes
  • 1 Post By jtec
  • 1 Post By CJ7-Tim
  • 1 Post By TheBoogieman
  • 1 Post By cruiser54
  • 1 Post By jeepguy03
  • 1 Post By axlaxl
post #1 of 13 Old 03-28-2020, 04:25 PM Thread Starter
axlaxl
So today marks the second time in the last month or so that I took a clover leaf entry/exit to a highway in the rain and the rear end let loose on me.
Both times it was steady rain and I was going very slow, like 20-25mph and the rear just swung out on me. Fortunately I learned to drive on a 72 VW Beetle and the rear would get loose on any left hand turn when it rained so i'm a decent expert at correcting a sliding rear end.
But, if i had been going a normal speed like 35 mph I honestly think both situations would have turned out much worse. This is my second XJ so I've got a lot of experience driving them in different conditions and never had this happen before.
I don't think its my driving habits. So I'm starting to think its the tires. The thing is, they have a decent about of tread still on them, but, my mechanic did say they are "choppy".
I'm currently running 30x9.5 BFG All Terrain A/T at around 38 psi due to the pot holes all over NYC.
At this point I think I am just going to buy a new set of tires and try to sell the old ones, but just wondering if anyone else has had a similar experience with an XJ.
Until then, should I lower the PSI? Could it be the shocks starting to get soft (something I've noticed lately)?
Any advice or opinion or general banter is always appreciated.
axlaxl is offline
post #2 of 13 Old 03-28-2020, 04:41 PM
jtec
jtec's Avatar
2014 JK Wrangler
tires was my first thought - what tire size info is listed on the driver door decal?
Your rear diff is not locked, ie a locker, anything in rear of jeep 30 cases of beer?
xjpro likes this.
jtec is offline
post #3 of 13 Old 03-28-2020, 05:24 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
38 psi, OMG how do you keep the fillings in your teeth ? Somewhere between 28-32 psi would be better.
Regarding All Terrain A/T BFG's, I have found that as they get older and the tread depth diminishes, they do tend to get slippery in the rain.
What does the tread depth measure ?
jeepguy03 likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 13 Old 03-28-2020, 11:50 PM
fawndog
fawndog's Avatar
I've felt this on "hard tires" with a posi, I think posis tend to break loose sooner too. New rubber for sure, will change that feeling.
fawndog is offline
post #5 of 13 Old 03-28-2020, 11:53 PM
ZR7 Ken
ZR7 Ken's Avatar
+1 on tires. I had a V8 Dodge Dakota that I couldn't keep the rear straight in the rain on the factory Goodyear tires. I replaced them with some Michelins and it was night and day.
ZR7 Ken is offline
post #6 of 13 Old 03-29-2020, 08:08 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
You put enough air in those tires to hydroplane on drive pavement.
p.s. Too much air in your tires makes them worse on potholes, not better. If they're worn out, replace them.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #7 of 13 Old 03-29-2020, 08:15 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Drop the pressure as suggested and check the date code on the tires.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #8 of 13 Old 03-29-2020, 12:39 PM
riderboy1961
riderboy1961's Avatar
(if you are thinking of changing to different tires)
Best tires I have ever driven on to date: "Nitto A/T Terra Grappler G2" 10ply - Super Quiet on highway.
These tires were on a vehicle I purchased a couple years ago. I was not too fond of the Looks of these tires But, as I drove on them and began to really appreciate them. Super heavy duty (10 ply) and were the Quietest Tires I have ever driven on including any passenger tires!!
Excellent Traction in Rain/Standing Water.
Thank You,
Bo
riderboy1961 is online now
post #9 of 13 Old 03-29-2020, 12:42 PM
jeepguy03
Winning
jeepguy03's Avatar
Do the chalk test across the tires to see what the best pressure to run would be. When I had 30" BFG's on my XJ it was right around 28-30 PSI depending on what I was carrying.
TheBoogieman likes this.
0331 head swap DIY:
"Build" thread:
Previous: 1990 XJ Limited, 2000 XJ Sport, 2000 XJ Sport
Current: 1998 Wrangler Sahara
jeepguy03 is offline
post #10 of 13 Old 03-31-2020, 05:06 PM
jeepdave551
2016 ZJ
that your answer the peaks are the olny thing on the ground ,maby do a burn out get some flat spots the will rest on the road
jeepdave551 is offline
post #11 of 13 Old 03-31-2020, 06:13 PM
Beemer
The worst wet road tires I ever had on my xj were the BFG's. When I replaced them with Michelins, it was like a new ride. I didn't like the BFG's on dry pavement either. Hard braking usually induced a skid and hard acceleration would cause spin. After 20K on them with plenty of tread left, I replaced them.
Beemer is offline
post #12 of 13 Old 04-03-2020, 04:39 PM Thread Starter
axlaxl
Just had my 4 new Dick Cepek Fun Country 31's arrive and after one look at the tread depth I realized just how worn down my BFG's were.
Also, I adjust the PSI, I had read the gauge wrong, they were at 34 psi not 38, I dropped em down to 30 just to be safe. Will get the DC FC's mounted on Monday and toss the old ones.
axlaxl is offline
post #13 of 13 Old 04-03-2020, 05:48 PM
TheBoogieman
Distubed Jeepaholic
I'm a Dick Cepek tire fan, after many years of running Mickey Thompson MTZ tires. My Extreme Country tires are wearing excellent and very quiet for a MT. I replaced my almost new Goodyear Wrangler tires when I went up in size. I sold my Goodyear tires for $200 on craigslist.
