Long life antifreeze / coolant - trust it to last longer? - JeepForum.com
post #1 of 6 Old 10-16-2021, 08:26 PM Thread Starter
jbirdTX
I changed my antifreeze in my '01 XJ almost 3 years and 30,000 miles ago with the Prestone long life antifreeze that claims to last up to 5 years or 150,000 miles. The original maintenance schedule recommended changing it at 2 years or 30,000 miles. I want to see if other people trust the long-life claim or have experience with extending their service interval with long-life antifreeze. Do you save your time and money and trust the 5 years / 150,000 mile claim, and maybe just check your antifreeze with a tester at some point? Or, would you just stick with your original maintenance schedule?
jbirdTX is offline
post #2 of 6 Old 10-16-2021, 08:37 PM
Boojo35
1987 YJ Wrangler
Nothing lasts forever. I am a master tech of over 40 years. It is the shortest way to post this. I will say this again. Nothing lasts forever. Which is cheaper? Changing fluids too often or doing major repairs?
If you look at a vehicles factory maintenance schedule. I do not care who you are or where you drive. If you really read the schedules, your vehicle will qualify for severe maintenance rather than normal driving. This moves all maintenances forward by mileage and time.
Dont mess with extending the life of coolant. The downsides are plugged heater cores for instance which become more and more labor intensive in newer vehilces.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #3 of 6 Old 10-16-2021, 09:17 PM
nathan915
nathan915's Avatar
The long life coolant in theory has a better additive package so the corrosion resistance will last longer. This does nothing to help with contamination though. You'll still be circulating gunk and sediment through your cooling system after a couple of years. I would replace it now for the peace of mind. It's cheap and easy. Replacing parts is not.
nathan915 is offline
post #4 of 6 Old 10-17-2021, 12:27 AM
Ralph77
I use the green stuff so this is kinda like comparing apples to oranges.
But owning an '00 with the 0331 head I have a tendency to go overboard with maintenance.
I swap mine every other year. And at best thinking there is 6K on it when I do.
One reason is that there is always about a gallon left in there when I do.
Another reason is I pay $10 for a gallon of full strength stuff and a gallon of distilled water runs a buck.
So that gives me the 2 gallons I need to do the job. So I am OK with spending $6 a year. LOL.
Last I own a Lisle funnel. With that and my Ext Idle switch taking my time it is about a 75 minute job.
And about 45 minutes of that is me standing around while she is running letting all the air burp out.
So between the cost and the time it takes to do the job I don't see how I can not do what I do.
Ralph77 is offline
post #5 of 6 Old 10-19-2021, 12:50 PM
Fourspeedman
Fourspeedman's Avatar
I too use the old green stuff in my XJs. The "long life"and all the other specialty coolants are really for the all aluminum systems. And even those I don't trust to last as long as they claim. The only aluminum in an XJ is the radiator and water pump so the green stuff works just fine as long as you use distilled water. Tap water has too many minerals and will allow galvanic corrosion between the aluminum and cast iron.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #6 of 6 Old 10-28-2021, 09:35 PM Thread Starter
jbirdTX
So, I went ahead and changed my coolant last weekend and found some sediment in the system. It wasn't severe, but it was good to go ahead and flush it out.
jbirdTX is offline
