Lifting Stock XJ - JeepForum.com
 3Likes
  • 1 Post By Michaelj51
  • 1 Post By CJ7-Tim
  • 1 Post By ddraeg
post #1 of 13 Old 11-26-2019, 05:45 PM Thread Starter
D917
Hello.
I have a stock 1999 jeep Cherokee XJ sport. It's a daily driver and it's not used for offroading.
The rear is sagging and i figured this could be a good time to lift the Cherokee.
I have a set of tires 265/75R16 on TJ Rubicon MOAB wheels in storage. Originally planned for a wrangler but that changed. These are almost 32" tires. I believe they are 31.6" in height.
I'm looking at 4.5" lift from Rough Country. It's currently 900$. Specifically the: 4.5IN JEEP X-SERIES SUSPENSION LIFT SYSTEM
I know not many are fans of rough country. But i dont want to spend a lot and that's where rough country comes in. Again I don't use the jeep for offroading. If i were to guess i maybe drive the jeep 5000 miles a year
Some oncerns, i don't want to remove the original fender flares. I'm willing to trim the "skirt" from the underneath of the front bumper if needed.
Can i use the 4.5 rough country lift without removing the original fender flares? I dont plan on any offroad use.
Is this a direct bolt on lift kit? What other parts should i anticipate purchasing that the lift kit does not include?
Finally, the long arm lift kits, are those mainly for offroad use?
I attached a pic of what i would want my jeep to look like and my current stock status.
I appreciate any insight.
Screenshot_20191126-184708_Gallery_1574815655167.jpg   20190620_184242_1574815694662.jpg
D917 is offline
post #2 of 13 Old 11-26-2019, 06:01 PM
Michaelj51
Originally Posted by D917 View Post
Hello.
" I don't plan any offload use" ??
I can't imagine why you'd want to spend the money / labor costs. Loose gas mileage and handling characteristics etc.. if you are not intending some fairly serious offload use?
Michaelj51 is offline
post #3 of 13 Old 11-26-2019, 08:47 PM Thread Starter
D917
Anything close to off roading would be the snowy winters in the midwest.
D917 is offline
post #4 of 13 Old 11-26-2019, 10:01 PM
Michaelj51
Your stock xj, with it's lower center of gravity, will do much better on snowy roads, especially if there are other vehicles using them [ traffic] than the lifted version.
Except,of course, for empty parking lots and squirreling around
Kolak likes this.
post #5 of 13 Old 11-27-2019, 12:31 AM
Ralph77
Plus what people seem to forget is that you want the pizza cutter size tires for the snow
At least you used too.
Maybe things have changed.
I just run a 225 75 15 on a stock Jeep all year round.
But if I ran different tires in the winter they would be 215's.
Ralph77 is online now
post #6 of 13 Old 11-27-2019, 12:55 AM
ddraeg
ddraeg's Avatar
I just did mine, didn't really want to lift but gained about 3 1/2" over my worst corner, I think generally its now 1 1/2 over stock.
Video of me doing it.
ddraeg is offline
post #7 of 13 Old 11-27-2019, 04:54 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
No lift kit is complete, some lift kits are more complete than others. Don't forget extended bumpstops.
At 4.5" of lift, 32's will fit fine, maybe requiring trimming some plastic. XJ lift kits do "bolt on" , but expect some rust seized bolts. Long arms are more for off-road, control arm drop brackets are less expensive and do about the same thing.
Read a ton of threads about lift kit installs, rust seized leaf spring bolts, and broken shock bolts.
My green 1998 is lifted 3" and has never been off road. I have the big blue XJ with 5.5" of lift and a lifted CJ-7 to play in. I used to daily drive the blue XJ summer and winter lift kit and all, no problems.
TheBoogieman likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #8 of 13 Old 11-27-2019, 07:54 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
We got 3' of snow is 2009 and my stock XJ wouldn't get out of my driveway. My lifted Jeep cruised through my 5 hour driving job though.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #9 of 13 Old 11-27-2019, 08:01 PM
TheBoogieman
Distubed Jeepaholic
Because it's his Jeep and money. My lifted Jeeps with the wider stance are far more stable than stock. My Rubicon gets 16.5 mpg.
post #10 of 13 Old 11-27-2019, 08:13 PM
TheBoogieman
Distubed Jeepaholic
CJ7-Tim answered your questions best. I'd go with Zone over RC. Remember, it's the shocks that make or break the ride quality. I recently swapped some Rancho rs5000x shocks on mine and couldn't be happier with the ride.
p.s. Nice looking Jeep. I love red Jeeps.
post #11 of 13 Old 11-27-2019, 08:27 PM
TheBoogieman
Distubed Jeepaholic
You will definitely need a longer rear brake hose (not lines). A stock YJ line works great, is cheap and 4" longer. I would also buy these in advance in case the rear upper shock bolts snap off. RC sells them.
post #12 of 13 Old 11-28-2019, 03:29 AM
ddraeg
ddraeg's Avatar
These would be great. I fished bolts on one side but on the other side I couldn't for the life of me knock those captive nuts out. I had to cut a hole in the floor and work down. They had a lot of weld on them and I had to Dremel it off before spinning off with a socket. This did allow me to weld the new bolts in position.
ddraeg is offline
post #13 of 13 Old 12-06-2019, 02:58 PM
KF4SQB
1994 XJ Cherokee
When you lift 4-link front ends (like the XJ), you cause an alteration of the angle of the control arms. This causes the control arms to be more "straight on" to bumps, making for a rougher ride. The more lift, the worse the problem. At 4.5" of lift, you will definitely want to consider this. There are two solutions to this issue.
The first, and best, is long arms. This effectively moves the rear of the control arm toward the rear of the vehicle, allowing for a shallower control arm angle and a better ride. The drawback is some complexity to the install, but it is not that bad.
The second method is a set of drop brackets for the control arms. This corrects the control arm angle by lowering the point where it mounts to the frame of the vehicle. The drawbacks to drop brackets are (possible) ground clearance issues, due to the drop brackets themselves, and greater stress on the control arm brackets and frame rail. If you have no plans for offroading, either method should work fine for you, and will give you a better ride.
If you would like to correct the rear end sag cheaply and without lifting, a set of rear leaves from under an early 2000s model 4X4 compact GMC Jimmy or Chevy Blazer will bolt up under an XJ with minimal modifications, and will restore your ride height to stock, or maybe a 1/2" or so of lift. It put mine to stock height, and I wish I had done it years before I did!
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
