Late shift when cold 2000 xj 4x4 auto trans - JeepForum.com
 2Likes
  • 1 Post By CLASSIC2000MST
  • 1 Post By 2oldjeeps
post #1 of 7 Old 05-02-2021, 11:22 PM Thread Starter
CLASSIC2000MST
Transmission shifting problems..
2000 cherokee classic xj auto trans. 4x4 350k miles.
Most often when cold, will not shift out of 1st gear for a block or two.... Even if rpm is up to 3000.. Clears after couple blocks.
Most often when cold, initial shift from park to drive is very hard and abrupt.
Most often when cold slight clicking sound as if gear is not being lubricated fully ... Ends after driving a few blocks.
Fluid does not smell burnt. Looks to be proper level.
Thoughts?
CLASSIC2000MST is offline
post #2 of 7 Old 05-03-2021, 04:57 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Adjust the the throttle valve cable on the throttle body, (often incorrectly called the kickdown cable). Test the Throttle Position Sensor, the TPS data is used used by the Transmission Control Unit for shifting. Test the transmission shift solenoids.
If you are not certain the trans fluid is the recommended Dexron-III/Mercon, you should perform a complete fluid exchange. DO NOT get a power flush.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 7 Old 05-03-2021, 07:21 AM
superj
superj's Avatar
yup, something is not right because we have the same mileage on our Cherokee and it shifts perfectly. my wife still drives it to and form work each day
the xj is the only jeep left in the driveway
superj is offline
post #4 of 7 Old 05-10-2021, 09:26 PM Thread Starter
CLASSIC2000MST
Many many thanks for the input..... I replace the throttle position sensor and it appears to have solved the late shifting problem.... and the engine is running noticably smoother.
So it appears my fear about having to get a new transmission was premature.
superj likes this.
post #5 of 7 Old 05-11-2021, 06:41 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Drain and refill per Tim's suggestion anyway.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #6 of 7 Old 05-17-2021, 06:00 PM
2oldjeeps
2oldjeeps's Avatar
when i got my xj i did simple drain and fill 3 times in 3 months. its been great, but im reminded, i should treat it good as it treats me, do it again...its cheap... love my jeeps...
cruiser54 likes this.
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #7 of 7 Old 05-17-2021, 06:03 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This^^ and TV cable adjustment.
