Jeep won't start - JeepForum.com
post #1 of 10 Old 08-24-2015, 04:21 PM Thread Starter
chevydude5o2
1997 XJ Cherokee
Jeep won't start
I have a 97 xj 4.0 that won't turn over, when I turn the key everything works except it won't start or turn over, I do here slight clicking on the passenger side inside the jeep but not the from starter I think it's the relays clicking. I already changed the starter and cleaned up the neutral safety switch, we can start it at the starter with a screw driver, the battery tested good. It won't start in park or neutral. I'm really confused, it was working fine yesterday, went to the store and then nothing, any ideas??
1997 XJ - 3in lift 31in mud terrains
1994 xj - RIP
chevydude5o2 is offline
post #2 of 10 Old 08-24-2015, 04:38 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Clicking and not starting is usually a low voltage issue from:
• a failing battery
• a failing alternator
• dirty, corroded, damaged, or loose wire connections
• internally corroded battery wires
• leaving the lights on
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Copper wires should be copper color, not black or green. Do the same for the grounding wires from the starter to engine block, the ground wires at the coil, and the ground wires from the battery and engine to the Jeep's frame/body. You must remove, wire brush, and clean until shiny the cable/wire ends and whatever they bolt to.
Jeeps do not tolerate low voltage, bad wire connections, or poor grounds.
Place your DVOM (Digital Volt Ohm Multi-Meter) on the 20 volt scale. First check battery voltage by placing your multi-meter's positive lead on the battery's positive post ( the actual post, not the clamp ) and the negative lead on the negative post. You need a minimum of 12 volts to continue testing. Next, leave your meter connected and take a reading while the engine is cranking. Record this voltage reading. Now connect your positive lead to the battery terminal stud on the starter and the negative lead to the starter housing. Again, crank the engine and record the voltage reading. If the voltage reading at the starter is not within 1 volt of battery voltage then you have excessive voltage drop in the starter circuit.
Typical voltage drop maximums:
• starter circuit (including starter solenoid) = 0.60 volt
• battery post to battery terminal end = zero volts
• battery main cable (measured end to end) 0.20 volt
• starter solenoid = 0.20 volt
• battery negative post to alternator metal frame = 0.20 volt
• negative main cable to engine block = 0.20 volt
• negative battery post to starter metal frame = 0.30
• battery positive post to alternator b+stud = 0.5 volt with maximum charging load applied (all accessories turned on)
Test the output at the alternator with your volts/ohms multi-meter. You should be measuring 13.8-14.4 volts. Load testing the alternator is still recommended.
Exchange the ASD relay with a similar relay in the fuse box under the hood near the battery.
Have your helper turn the ignition key to START while you tap on the starter with a hammer. If the engine starts, you probably need a new starter.
Have the battery, starter, and the alternator Load Tested for proper function in a test machine that applies a simulated work load. Handheld testers are inaccurate and will often pass faulty parts.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 10 Old 08-24-2015, 04:49 PM Thread Starter
chevydude5o2
1997 XJ Cherokee
• a failing battery
All the connections look good, the starter is brand new, we can get it to start by touching a screw driver to the connections on the starter, also the battery is good, it was tested. The clicking is not coming from the starter, it very soft coming from inside of the cab from the relays I think, I don't think it's a power issue at all.
1994 xj - RIP
post #4 of 10 Old 08-24-2015, 04:56 PM
CJ7-Tim
CJ7-Tim's Avatar
The connections "look good" or test good ? If the starter is rebuilt, and has a 'Lifetime Warranty", it is suspect.
Clicking and not starting is almost always poor quality connections.
- Benjamin Franklin
CJ7-Tim is offline
post #5 of 10 Old 08-24-2015, 05:04 PM Thread Starter
chevydude5o2
1997 XJ Cherokee
If we can get it to start by touching the connections on the starter with a screwdriver would it still be a power issue or maybe an issue with sending the signal from the ignition switch?
1994 xj - RIP
post #6 of 10 Old 08-24-2015, 05:38 PM
jonsnw93
You said it won't start in park or neutral. Does it crank or nothing, if nothing it could very well be your NNS
jonsnw93 is offline
post #7 of 10 Old 08-24-2015, 05:41 PM Thread Starter
chevydude5o2
1997 XJ Cherokee
I already took apart and cleaned it, everything looked good, it doesn't crank, the only way to get it started right now is to touch the connections on the starter with a screwdriver
1994 xj - RIP
post #8 of 10 Old 08-24-2015, 05:43 PM
jonsnw93
The NNS could still be bad. I would pull your starter first and have an auto parts store test it. The solenoid could be bad
jonsnw93 is offline
post #9 of 10 Old 08-25-2015, 05:34 AM
MaskedMallard
Do you have an alarm system?
Have you changed ignition keys recently?
MaskedMallard is offline
post #10 of 10 Old 08-25-2015, 08:54 AM
bluejunior
bluejunior's Avatar
The security system lets it start and run for 3 seconds, then kills the engine. I am overly familiar since the sensor in my steering column went bad. Had to get a new PCM for closer to $300 than I'd like, but his symptoms aren't that.
Could be a misalignment of the NSS rather than a bad NSS. Do your reverse lights come on normally? You could also test it by disconnecting the NSS and jumping the wiring harness to the PCM to guarantee it thinks it's in park.
Have you checked for good voltage going into the starter relay while a buddy turns the key for you? that would be a good way to test that it's getting proper signal.
I don't think it's your starter or the power wire for it if it starts easily from jumped terminals, though any store brand "lifetime warranty" part is suspect as others have mentioned. Have you tried swapping the starter relay with one of the others to make sure it's not the relay itself?
I know that's several things but combined they shouldn't take long and would give more information.
Lifted, Locked, Stiffened
bluejunior is offline
electrical , ignition , nss , starter , starting
