Instrument cluster lights only work sometimes - JeepForum.com
post #1 of 9 Old 11-22-2019, 10:25 AM Thread Starter
crruuska
1994 XJ Cherokee
Hey all,
I have a 94 Cherokee and the lights on the gauges never seem to work properly. Usually they will be somewhat lit up and then a little while later they will stop illuminating. Is this a common problem? Could it be my grounds?
crruuska is offline
post #2 of 9 Old 11-25-2019, 12:59 AM
CherokeeTamer
1991 XJ Cherokee
Is it just your instument cluster lights or all dash lights? If it's all dash lights (shifter, ac controls, etc.) Then you may want to consider replacing the headlight/dimmer switch. Mine started doing this a few years back and I found that it was the culprit.
CherokeeTamer is offline
post #3 of 9 Old 12-01-2019, 02:01 AM Thread Starter
crruuska
1994 XJ Cherokee
I'll have to check tomorrow. I believe it is all of the interior lights. If not, what other culprits are there?
crruuska is offline
post #4 of 9 Old 12-06-2019, 03:23 PM
KF4SQB
1994 XJ Cherokee
The headlight/dimmer switch, or a bad ground will be the most likely culprits. I'm putting my money on the switch.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #5 of 9 Old 12-09-2019, 12:17 PM Thread Starter
crruuska
1994 XJ Cherokee
On Napa, the headlight/dimmer switch is the turn signal stalk. Is that what you're referring to? On the stalk I've noticed the push button on the end of it doesn't do anything when pushed and the switch doesn't do anything either. It seems like it would be for cruise control.
crruuska is offline
post #6 of 9 Old 12-09-2019, 06:12 PM
KF4SQB
1994 XJ Cherokee
We were referring to the headlight switch in the dash, on the far left side. The "dimmer" that CherokeeTamer referred to is the dimmer for the dash lights, which is incorporated into the headlight switch. That is the feature that allows you to turn the knob of the headlight switch and dim/brighten the dash lights. You may want to try turning the knob both ways with at least the parking lights turned on and see if you get any light at any point of the adjustment. It is not uncommon for the variable resistor that makes up the dimmer circuit to break along its length, causing the lights to not work if it is adjusted beyond that point. The "headlight dimmer" you were referring to from NAPA is the dimmer switch to switch between high and low beams for the headlights. The interior lights do not route through that particular switch.
KF4SQB is offline
post #7 of 9 Old 12-13-2019, 02:28 AM Thread Starter
crruuska
1994 XJ Cherokee
Okay thank you. Do you know what the function of the switches on the turn signal stalk are? The wipers work but the push button on the end and the switch close to the end do not work. It seems like they would be for cruise control but I don't think the 94' had that. Could be wrong though.
crruuska is offline
post #8 of 9 Old 12-17-2019, 01:33 PM
KF4SQB
1994 XJ Cherokee
Cruise control was indeed an option in '94. The button on the end of, and switch on the side of, the multi-function switch stalk would indeed be for cruise. The controls shouldn't be there unless the vehicle has cruise, unless someone before you replaced the stalk with one for cruise. Look under the hood. If there is an actuator mounted to the firewall, with a cable connecting it to the throttle body, yours came with cruise. Its possible that you have it, but it doesn't work.
KF4SQB is offline
post #9 of 9 Old 12-18-2019, 07:08 AM
Wallyb4
Junior Member
Wallyb4's Avatar
1997 XJ Cherokee
Also check the grounds in the engine compartment on the drivers fender well and on the fire wall.c Make sure they are clean and tight. I had the same issue and found out it was the grounds. Good luck.
Walter Ballard
97 Jeep Cherokee 4.0L
My Toy.
Wallyb4 is offline
