Ignition Issue -- HELP!!! - JeepForum.com
post #1 of 4 Old 08-15-2015, 02:27 PM Thread Starter
leichte
For a few weeks, I noticed that I was having to turn the key a little farther than normal each time I started my 87 XJ. Then when I turned it off, it started getting caught just before being put in the OFF position. It would be hard to turn and make a lock click when it did turn.
Finally, no matter how far I turned it, there was no start. Everything else would come on - lights, blinkers, a/c, etc, but the truck wouldn't even crank. I took the ignition switch off and it looked okay, but the rod would only go back to off a few times when I moved it by hand. Another reason I didn't think it was the ignition switch. I also replaced the ignition cylinder (where the key goes). Still nothing changed.
I stripped the steering wheel down to where the actuator rod turns from the key and now it moves to OFF but it still makes the hard click sound and doesn't start. Can't see it catching on the teeth wheel.
I gotta get this thing started. Any ideas?
Thanks!
leichte is offline
post #2 of 4 Old 08-19-2015, 06:15 AM Thread Starter
leichte
Any thoughts?
leichte is offline
post #3 of 4 Old 08-19-2015, 07:26 AM
bryanintowson
1994 ZJ
How worn down is your actual key?
1994 Grand Cherokee Limited, 5.2
1992 Cherokee Laredo - SOLD
2002 Wrangler Sport - SOLD
bryanintowson is offline
post #4 of 4 Old 08-19-2015, 08:40 AM Thread Starter
leichte
The first thing I did was install a new ignition cylinder. So the key is brand new.
leichte is offline
ignition , start , steering column , switch , xj
