IAC issues, help plz - JeepForum.com
post #1 of 16 Old 03-12-2016, 01:46 PM Thread Starter
svshaw82
1989 XJ Cherokee
Hey guys! Engine specs, 1989 4.0 renix. Ive replaced my IAC, clean it thoroughly and the throttle body. I'm experiencing a high random idle that goes over 2000 RPMs. The only solution I've been able to find is wait for the IAC to catch up with the idle and unplug it. That's been the only way to control it so far.
Is there anything in the wiring harness that I can check for? I've gone through 3 IACs now. All of them have the same result and it just happened out of nowhere.
Since I rebuilt the engine I went through my wiring harness and got rid of all the ground blocks, and gave each circuit a dedicated ground to the firewall. Engine has been broken in for about fifteen hundred miles, so far all was well until a few weeks ago. Sometimes it starts normally sometimes it starts at over 2000 RPM, and once it goes over that range it will not come down. I've only been able to get it to come down after turning the engine on and back off several times, and then I unplug the IAC once idle is normal.
Are there any specific voltages to certain wires that I can check for, or ohm readings? Any help is much appreciated thank you!
svshaw82 is offline
post #2 of 16 Old 03-12-2016, 01:51 PM
PimaXJ
1997 XJ Cherokee
There is a way to test the IAC a least on the newer 4.0. Do a search.
PimaXJ is offline
post #3 of 16 Old 03-12-2016, 02:00 PM Thread Starter
svshaw82
1989 XJ Cherokee
Brand new out the box same symptoms as old one? You think I have bad IAC?
svshaw82 is offline
post #4 of 16 Old 03-12-2016, 09:13 PM
ECL
Is there a throttle position sensor on that year? Might be worth checking.
ECL is offline
post #5 of 16 Old 03-12-2016, 10:42 PM Thread Starter
svshaw82
1989 XJ Cherokee
The TPS is only a few years old
svshaw82 is offline
post #6 of 16 Old 03-12-2016, 10:54 PM
shooptube
Big Brother
shooptube's Avatar
1997 XJ Cherokee
That doesn't mean it couldn't have went bad since
Originally Posted by Luke95 View Post
I am Moar low.
Build Thread:
Instagram:
shooptube is offline
post #7 of 16 Old 03-14-2016, 07:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sounds like bad TPS.
Test it. Tip 8 in my link below.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #8 of 16 Old 03-14-2016, 10:57 PM Thread Starter
svshaw82
1989 XJ Cherokee
No link shown bud
svshaw82 is offline
post #9 of 16 Old 03-15-2016, 12:59 AM
shooptube
Big Brother
shooptube's Avatar
1997 XJ Cherokee
No link shown bud
Its part of his signature
http://cruiser54.com/
I am Moar low.
Build Thread:
Instagram:
post #10 of 16 Old 03-15-2016, 07:28 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Maybe it doesn't show on the App?
http://cruiser54.com/?p=54
post #11 of 16 Old 03-21-2016, 06:06 AM Thread Starter
svshaw82
1989 XJ Cherokee
Think i figured out the issue. During motor rebuild i went though my wiring harness. Cutout all ground blocks and extended all grounds to the firewall.
The big copper lug i used had corroded a little and was loose. Sanded, wire brushed, greased it, and retorqued it.
Problem dissappeared. :-)
svshaw82 is offline
post #12 of 16 Old 03-21-2016, 06:54 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Those grounds aren't important.........LOL.
post #13 of 16 Old 03-21-2016, 07:25 AM Thread Starter
svshaw82
1989 XJ Cherokee
Lol well I didn't suspect the lug at first because I used dielectric grease when I made the connector. Then wrapped it with electrical tape. It wasn't until the engine was at a high idle I grabbed it. When I moved it slightly the idle came back down. Lol
svshaw82 is offline
post #14 of 16 Old 03-21-2016, 07:36 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Thanks for reporting back. There's a better product or 2, which are conductive and lock out air. One is NoAlOx.
post #15 of 16 Old 03-25-2016, 02:32 PM Thread Starter
svshaw82
1989 XJ Cherokee
Thanks Cruzer. Might be putting a new lug on after our big bear trip. Although it was a solid copper lug, and crimped on with a big wrench. Also used an old battery cable to run a second ground off the same lug to the intake manifold.
So I have battery ground to the block, battery ground to the body, firewall grounds for all injectors and sensors, and firewall ground to intake manifold. Should cover everything right?
svshaw82 is offline
