How should a lifted XJ drive? - JeepForum.com
 5Likes
post #1 of 20 Old 10-16-2020, 07:21 PM Thread Starter
HoundDogXJ
As I posted in another thread a second ago, I had a shop put a small lift kit on my 2000 Jeep Cherokee XJ, they used a Detroit Axle front-end rebuild kit I purchased and I bought new 15x8" wheels for it with 30x9.5x15 Mastercraft ATX tires they offered. Before the work was done, everything up front was worn out but it still handled good, was peppy as heck and ran 75 - 80mph with no problems. Now, 70 mph is pushing her, she handles like a pig ice skating with 2 shoes missing blades and the front end is popping and cracking to beat the band. One thing, I can't put my finger on though, it feels like it is fighting itself going down the road or like everything under her is binding up. Is this normal results from doing a baby lift and bigger tires? Man, I hope not.
HoundDogXJ is offline
post #2 of 20 Old 10-16-2020, 07:29 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Describe the lift kit parts in full and complete detail. Were all the steering parts replaced as well ? Were the axle and sway bar bushings replaced ? What kinda shop did the work ? All the bolt and fastener torques we re-checked after 100 miles ? Who did the alignment after the lift ?
If you rode in my 99 with 1" lift and 30x9.5, my 98 with a 3" lift and 31x10.5, or my 00 with a 5.5" lift and you were wearing a blindfold, you would be lucky to guess which one you were in. There should be absolutely no noises or major handling issues with a properly installed lift kit.
skjeep and underscore like this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 20 Old 10-16-2020, 07:51 PM
underscore
2007 WK
Were things retorqued at ride height? Has it had the alignment checked since the lift?
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #4 of 20 Old 10-16-2020, 10:30 PM Thread Starter
HoundDogXJ
Fully professional 4x4 shop did the work. That's all they do. Yes to the realignment. Yes to the ride height or that is what they told me. The new track bar could not be installed due to the old one being "locked in." All new bushings, shocks, leaf springs, Detroit Axle front end rebuild kit, ball joints...I'm just glad to hear it shouldn't be driving like a horse cart with Baja suspension pieces tacked on. My fear is they shanked my hinny. I hope they sleep good this weekend, restitution is going to be a Witch.
The one statement that sticks in my mind the most is, "This is what I get trying to be nice to someone and fix their POS. I should never have touched it!" The absolute gall of this punk. I just paid their shop $2500(+) and he did me a favor? Plus the other shop $120 to fix my brakes so I could drive home.
post #5 of 20 Old 10-17-2020, 05:52 AM Thread Starter
HoundDogXJ
I tried to upload the word document with all the work done, pictures included but keep getting error notices. Suggestions?
post #6 of 20 Old 10-17-2020, 08:24 AM
CJ7-Tim
CJ7-Tim's Avatar
I do not think you can upload documents to Jeepforum. You can take pictures of documents, host them on a website like www.fototime.com, and then post pictures of the documents.
I still want to see the list of parts installed, but the lack of a new trackbar catches my attention.
HoundDogXJ likes this.
- Benjamin Franklin
CJ7-Tim is offline
post #7 of 20 Old 10-17-2020, 09:40 AM
2oldjeeps
2oldjeeps's Avatar
yeah you cant post pix like this...
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #8 of 20 Old 10-17-2020, 11:00 AM Thread Starter
HoundDogXJ
Finally have pictures
Here are some pictures that offer more insight.
Suspension thumbnail.jpg   American Racing Ansen AR969.jpg   Rough Country thumbnail.jpg   Steering stabilizer thumbnail.jpg   Lifted XJ thumbnail.jpg
post #9 of 20 Old 10-17-2020, 11:40 AM Thread Starter
HoundDogXJ
Just some more information. I pulled out of my drive and it may be a 2 inch drop to the flat pavement and the squeaking and popping was stunning. Dang jacklegs!!! Blood pressure is spiked! Before my old girl was worn out in the suspension department but squeaks pops or rattles were so minor...man I can't stand a liar or a thief but both inside a business should be enough to get that shop closed down.
post #10 of 20 Old 10-17-2020, 12:10 PM
CJ7-Tim
CJ7-Tim's Avatar
I see a new trackbar, did it get installed ? I do not see any new control arms, so did new control arm bushing get installed ?
At 2" of lift, a stock track bar will be slightly too short causing the front axle to not be centered under the body. and can cause noticeable odd behaviors when the supspension compresses.
- Benjamin Franklin
CJ7-Tim is offline
post #11 of 20 Old 10-17-2020, 04:36 PM Thread Starter
HoundDogXJ
Good point on the track bar.
At 2" of lift, a stock track bar will be slightly too short causing the front axle to not be centered under the body. and can cause noticeable odd behaviors when the suspension compresses.
The control arms they provided are installed. As I said earlier, they couldn't install the track bar. Your analysis may be the issue behind the weird handling, popping and cracking I'm hearing. Dang bums!!!
post #12 of 20 Old 10-17-2020, 07:18 PM
CJ7-Tim
CJ7-Tim's Avatar
The front axle should be centered +/- 1/4 inch or less under the body. You can simply measure both sides from the same feature on the tire tread or to a carpenter's level pressed to the tire sidewalls to either the shaft of the shocks, or to the mirror image features of the unibody.
A worn track bar or ovaled axle side track bar bracket bolt holes can cause clunking or knocking, and an offset front axle can cause odd handling behaviors, along with additional stresses on the track bar, causing additional clunking.
I strongly suspect track bar issues.
- Benjamin Franklin
CJ7-Tim is offline
post #13 of 20 Old 10-18-2020, 03:38 PM Thread Starter
HoundDogXJ
CJ7-Tim is the man!
I watched several folks demonstrate Track Bar issues on You Tube last night and one young man, man I wish I remembered his name - he was wearing a motocross helmet - did such a great job explaining how to spot the issue you describe. I included pictures showing the axle is off a touch too much towards the drivers side. When you spend your hard earned money and you depend on someone to just do the right thing...heck, just do your job!!!
post #14 of 20 Old 10-18-2020, 03:59 PM
W4JDZ
W4JDZ's Avatar
Take an ad out on Craigslist:
If you want to screw up your Jeep or other 4X4, take it to xyz company. After they work on it your vehicle will be undriveable. Their work includes clunking, rattles and a total lack of control at no extra cost. Be sure to call (phone #) to increase your blood pressure and lower your bank account.
Of course, don’t put your name or number in the ad.
OCDXJ likes this.
Some people just call me Doug.
W4JDZ is offline
post #15 of 20 Old 10-18-2020, 04:17 PM Thread Starter
HoundDogXJ
I like it!
Great idea! If I don't do it today, I'll try to do it tomorrow!
