How many mpg's am i loosing out on? - JeepForum.com
post #1 of 12 Old 09-09-2012, 11:40 PM Thread Starter
Jeepnbo
96 4.0 217xxx. Broken 02 sensor, and could use a typical tune up. How many mpg's am i loosing between these two factors? I know its not a hybrid for gas but just woundering if its actually worth fixing both of these as right now the xj runs fine and doesnt seem to be lagging power? 3.55 auto, 3'' lift on 31's.
Jeepnbo is offline
post #2 of 12 Old 09-10-2012, 12:02 AM
sAe23
1995 XJ Cherokee
...What are you getting AT THE MOMENT??
MPG can vary widely between similar vehicles...
And searching the forum will reveal dozens of MPG related threads.
As for whether it's WORTH doing a tune up and fixing important emissions related components, guess that depends on how many miles you drive annually and if the state does smog checks.
sAe23 is offline
post #3 of 12 Old 09-10-2012, 12:27 AM Thread Starter
Jeepnbo
well im putting on usually 300-400 miles a week depends on work. Ive est. bout 12-15 mpg and no michigan doesnt do smog checks thats why ive been so lazy about it.
Jeepnbo is offline
post #4 of 12 Old 09-10-2012, 01:10 AM
straightsixjeep
Make your Jeep happy and give her the ol' tune up.
straightsixjeep is offline
post #5 of 12 Old 09-10-2012, 05:00 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Not only will a tuneup maximize your fuel efficiency, it will make your XJ more reliable.
One example is that I've seen rotors explode from age, etc. Do the work. You will get a good "return on your investment" in a number of ways.
NTK oxygen sensor, Champion copper plugs gapped to .035, quality plug wires, distributor cap and rotor. Check or replace air filter.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 12 Old 09-10-2012, 05:35 AM
straightsixjeep
X2^^ First thing I did when I bought my xj was a new cap, rotor, plugs, wires, and air filter. Made the mistake of getting bosch spark plugs, once the gurus on here found this out they told me to take them back and get champion copper plugs. The xj is super reliable, never let me down. You scratch your jeeps back and it will scratch yours.
post #7 of 12 Old 09-10-2012, 10:38 AM Thread Starter
Jeepnbo
Thanks fellas. I figured between the broken 02 sensor and plugs that need to be changed im loosing $$. Anybody recommend the accel tune up kit?
Jeepnbo is offline
post #8 of 12 Old 09-10-2012, 02:06 PM
tjwalker
tjwalker's Avatar
My recommendation is to stick with Champion plugs. Just go to your local parts store (my favorite is Napa) and they will be able to set you up.
tjwalker is offline
post #9 of 12 Old 09-10-2012, 05:14 PM
mbardeen
1995 XJ Cherokee
A tuneup is never a bad thing. It's amazing what replacing the coil, wires, distributor cap & rotors, and plugs did for mine.
However, unless you're opening your tank and letting your MPGs run loose like wild horses, I think the word you want is "losing".
mbardeen is offline
post #10 of 12 Old 09-11-2012, 03:13 AM
DullesJeep
DullesJeep's Avatar
1995 XJ Cherokee
+ 1 on the champion plugs. Cheap, no frills, no gimmicks. Everyone I know that has a Jeep swears by them and I've heard plenty of horror stories from people that have tried anything other than champions.
It's a Jeep thing. Sometimes I don't even understand.
DullesJeep is offline
post #11 of 12 Old 09-11-2012, 06:06 AM
straightsixjeep
If you want it to run like a champion you have to use champions
post #12 of 12 Old 09-11-2012, 08:36 AM Thread Starter
Jeepnbo
Champions it is!
Jeepnbo is offline
Radio loosing reception? jeepkid03 XJ Cherokee Technical Forum 6 02-14-2013 08:46 PM
jeep loosing power teamturbo11 XJ Cherokee Technical Forum 15 03-10-2011 09:52 AM
Loosing oil pressure idle F1504x2 XJ Cherokee Technical Forum 7 11-09-2009 03:56 AM
Loosing Coolant? Hella00XJ XJ Cherokee Technical Forum 31 03-23-2008 09:25 PM
Keep loosing the cap. LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 11 12-19-2005 10:10 PM
