How to find what rear locker - JeepForum.com
post #1 of 8 Old 01-21-2020, 03:09 PM Thread Starter
mattrowe
mattrowe's Avatar
1990 XJ Cherokee
I received the build sheet for my sons 96, i believe country addition, and all it says is an 8.25 corporate rear axle. but it is definatley locked or limited slip because both rear wheels spin the same direction, with out taking the rear cover off, is there anyway to tell if someone installed a locker, or it is a factory lim-slip.
And in what xj did a limited slip come in. Or how to find out.
Would any kind of after market locker click when making sharp turns
mattrowe is offline
post #2 of 8 Old 01-22-2020, 01:50 AM
Ralph77
Somebody could have welded it. Believe people used to refer to it as a Lincoln Locker. Guessing cause of Lincoln Welders.
So I have been told but never confirmed that you can see enough through the fill plug to tell.
Factory LSD carrier on top and an open carrier below.
If it is an aftermarket one thinking if you can see the through the fill whole it will jump right out at you.
Ralph77 is offline
post #3 of 8 Old 01-22-2020, 05:38 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The optional factory installed Limited Slip would be listed on your Build Sheet available from Chrysler/Jeep. Or, you can take the cover off and look inside. Some locker click in turns and some don't.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 8 Old 01-22-2020, 06:36 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Probably due for a fluid change anyway......
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 8 Old 01-22-2020, 06:29 PM Thread Starter
mattrowe
mattrowe's Avatar
1990 XJ Cherokee
Probably, need to change. the only thing it says on the build sheet id with the power train
All 4-Speed Automatic Transmissions
DGSS 4-Speed Automatic
AW4 Transmission DHAS
Lock-Up Torque Converter DHNS
Command-Trac Part Time 4WD System
DHSS Floor Mount Automatic Shift Lever DJHS
Dana M30/181MM Front Axle DMDS
3.55 Rear Axle Ratio
DRAS Corporate 8.25 Rear Axle EAAC
All Engines
ERH 4.0L I6 Power Tech Engine
And there is no tag on the rear cover, so someone had the bolts out.
mattrowe is offline
post #6 of 8 Old 01-22-2020, 06:37 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pull the cover. Take pics.
post #7 of 8 Old 01-22-2020, 07:03 PM
CJ7-Tim
CJ7-Tim's Avatar
DSA or DSAP - Anti-Spin Differential Rear Axle
- Benjamin Franklin
CJ7-Tim is offline
post #8 of 8 Old 01-22-2020, 08:45 PM Thread Starter
mattrowe
mattrowe's Avatar
1990 XJ Cherokee
so this means (DSA or DSAP - Anti-Spin Differential Rear Axle) limited slip
ok so mine says DRAS in front of the coporate 8.25 rear axle
mattrowe is offline
