Horn won't blow - JeepForum.com
post #1 of 11 Old 08-06-2019, 06:10 PM Thread Starter
morrie
Horn won't blow
Checked all the fuses and they appear to be ok. Is there anything else I can check to resolve the issue?
morrie is offline
post #2 of 11 Old 08-06-2019, 08:21 PM
sjerseyxj
try looking at the clockspring that is one of the symptoms. there is plenty of writeups on this site or youtube. good luck
sjerseyxj is offline
post #3 of 11 Old 08-06-2019, 10:17 PM
2oldjeeps
voltage on horn?. is the horn good?
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is online now
post #4 of 11 Old 08-07-2019, 11:06 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
You could check out the horn relay. Here is a diagram. It should click when the horn is depressed. If not, i would check the relay is in good condition, maybe swap it for another, and then test the electrical contacts at the relay for voltage and ground.
I often start at the relays becuse it can home in on which apart of the circuit is not working.
The clock spring is highly likely, but by no means the only possible fault.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 11 Old 08-11-2019, 07:16 PM Thread Starter
morrie
Exactly where's the horn located....cannot see it inside the engine bay. It must be hidden somewhere??
morrie is offline
post #6 of 11 Old 08-11-2019, 09:04 PM Thread Starter
morrie
Yes there is a click on the relay which is found under passenger side dash. There are 3 black relays next to The fuse box. The middle one clicks. What does this indicate...do I need to replace the relay or what? Please advise.
Sent from my SM-G920V using Tapatalk
morrie is offline
post #7 of 11 Old 08-11-2019, 09:15 PM
2oldjeeps
lay on ground. horn hidden behind bumper. hard to get to.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #8 of 11 Old 08-11-2019, 10:31 PM Thread Starter
morrie
Damn...thanks
morrie is offline
post #9 of 11 Old 08-13-2019, 02:32 PM Thread Starter
morrie
morrie is offline
post #10 of 11 Old 08-13-2019, 02:35 PM Thread Starter
morrie
This is the relays that are next to fuse box on passenger side. The one in the middle clicks when attempting to blow horn from steering wheel . Now what?? Do I replace that relay?
morrie is offline
post #11 of 11 Old 08-15-2019, 06:39 PM
2oldjeeps
get to it from underneath. on the pass side, ill look in morning...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
