horn does not work, any ideas - JeepForum.com
 4Likes
  • 1 Post By 2oldjeeps
  • 1 Post By Cutlass327
  • 2 Post By RLE
post #1 of 15 Old 02-17-2019, 12:54 PM Thread Starter
Submariner
Submariner's Avatar
1976 CJ5
I get a click in the relay when I hit the button and the fuse is good and the wires are conneceted to the horns.
What am I missing? it has to be somewhere between the relay and the horns.
not sure.
Any ideas?
Thanks
Oh yah, working on a 97 cherokee.....
Submariner and you wonder why I am this way LOL
Submariner is offline
post #2 of 15 Old 02-17-2019, 02:17 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Obviously the only thing between the horns and the relay is wires, what does your volts/ohms multi-meter tell you about the wire continuity and the voltage ? Having the answers to those questions, will decide if the horn itself needs testing, yes ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 15 Old 02-17-2019, 02:30 PM
2oldjeeps
had same problem, found a leftover horn in my barn. quik fix...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #4 of 15 Old 02-18-2019, 09:56 AM
jserna
1987 YJ Wrangler
If all of the above do not fix it, then it is the clockspring under the air bag. It is not a hard job, to replace it just takes some time.
jserna is offline
post #5 of 15 Old 02-18-2019, 01:41 PM
2oldjeeps
no clock,no clik
JWELK likes this.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #6 of 15 Old 02-19-2019, 09:05 AM Thread Starter
Submariner
Submariner's Avatar
1976 CJ5
i ahve replaced the clock spring, got the click but no horn.
Also have the cruise control light but no cruise control.
post #7 of 15 Old 02-19-2019, 01:07 PM
2oldjeeps
think it might be the HORN???
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #8 of 15 Old 02-19-2019, 01:11 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
First thing I'd do is grab a test light and check for power/ground at the horn. No power, you know it is electrical. Good power, chuck the horn and install new. Let us know if you do not have power or ground at the horn.
Submariner likes this.
Rick
Cutlass327 is offline
post #9 of 15 Old 02-19-2019, 01:36 PM
RLE
RLE's Avatar
I've had several horns fail. They don't like getting too wet, nor do they
like being in a wedding procession where the driver blasts away for 20 minutes.
For the information of any one who has not yet had to check their horn:
To get at the horn, you just crawl under the driver's side bumper, loosen
the inner fender (held to the frame with plastic snaps), and peel it back
to reveal the horn in the cavity behind the headlamp. You get a faceful
of mud and dust as you look up in there. Spit all that out and shine a
flashlight up in there and check for loose wires. Then have someone honk
the horn while you check for voltage with a meter. The horns (there are two)
unbolt easily enough for replacement.
Cutlass327 and Submariner like this.
RLE is offline
post #10 of 15 Old 02-19-2019, 01:37 PM
2oldjeeps
IF the horn is bolted to the car,run a wire from batt + to horn.if you hear no loud noise its the HORN....
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #11 of 15 Old 02-21-2019, 06:47 AM Thread Starter
Submariner
Submariner's Avatar
1976 CJ5
Well that is a sure fire test. Why did I not think of that. I will do that around noon today when it stops raining and the sun is out.
Thanks
post #12 of 15 Old 01-23-2020, 01:14 AM
Hamid
Hamid's Avatar
Good I passed by, got nearly the same problem, except my horn doesn't blow from the steering wheel, I guess it is the clock spring.
Is there a way to check or fix the clock spring?.
2000 Jeep Cherokee Classic. Built for export
432K Kilos.
Hamid is offline
post #13 of 15 Old 01-23-2020, 01:50 AM
Ralph77
Basically there is a big ribbon in the clockspring. Guys have taken them apart and fixed them. A Google search will pull up some threads on this.
Personally I don't like the idea of that. But that is me.
When I put cruise control in my '00 XJ that did not come with it the first clockspring I used went bad after a week. Having extra parts I had a second one to try.
I was able to determine that it was good by checking the continuity of the ribbon inside the clockspring with a meter.
Thing is I can remember exactly which of the 3(?) terminals I used to check that. I had the bad one out to so was able to determine where I was looking for the beep.
Ralph77 is online now
post #14 of 15 Old 01-23-2020, 02:49 AM
MaskedMallard
Xj
not sure.
Any ideas?
Thanks
Roll the window down & yell.
2001 BJC Orvis XJ Build -
MaskedMallard is offline
post #15 of 15 Old 01-23-2020, 11:19 AM
car6car
I would start by removing relay and trying jumper wire, you need to know which holes to use. Most likely it is 4 pin relay. 2 pins have about 60 Ohm resistance (solenoid), 2 other pins are +12V and pin going to horn. If you install jumper wire in + hole and horn hole, it should make sound.
Disclaimer: If you blow up your Jeep, it is not my fault
04 Grand (dead)
car6car is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
Dash lights work, kinda. HELP reedtyler76 TJ Wrangler Technical Forum 7 06-17-2018 02:53 PM
Uwharrie Work Day June 16th 2018 cranbiz North Carolina Jeep Forum 0 05-11-2018 01:48 PM
TPMS not beeping horn when training sensors gdk771 WJ Grand Cherokee Forum 5 02-20-2018 08:31 AM
CJ 7 Horn TMH1jeep New Members/Introductions 0 02-15-2018 04:16 PM
