help my cherokee sport dies - JeepForum.com
post #1 of 9 Old 03-29-2014, 04:28 PM Thread Starter
hippyblonde
I have a 1999 Cherokee sport it keeps losing power, I can be driving and it will lose power and stall, I can be idling and it dies, I have taken it to 3 mechanics who charged me a lot of money and it is still not fixed, I have had the fuel pump replaced and the throttle position sensor replaced and the neutral safety switch replaced, I don't trust mechanics anymore, and the problem is getting worse thanks
hippyblonde is offline
post #2 of 9 Old 03-29-2014, 04:56 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Is your check engine light on? If so, post the exact codes here for comment (not just a description).
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 9 Old 03-29-2014, 06:17 PM
foreveryoung001
I would go back to all three mechanics and demand my money back. You paid them to solve a problem that wasn't solved. Paying a mechanic to throw parts at a problem is even worse than doing the work yourself.
As for figuring out your problem, I would start with the basics. How do your plugs look? Do they need to be replaced? Are they gapped at .35? Are you getting a good spark? Then I would check fuel pressure. Just because they put in a new pump, doesn't mean they did it correctly, or that it wasn't a bad pump that they replaced it with. Check the actual fuel pressure at the rail. Check your air filter. I've done hours worth of troubleshooting on vehicles, only to realize I had a nasty dirty air filter that was causing all my grief... And while you're checking your air filter, see if your throttle body needs to be cleaned.
I would also take it to a parts store that will read your codes for free, and as tjwalker suggested, post the codes you get. There may be stored codes that are not causing the CEL to come on, so its always good to get the codes read when troubleshooting a problem.
Once you get past the basics, if the problem isn't identified, we can start narrowing it down further. Its pointless to keep throwing parts at it though, hoping that it "might" be whats causing your issues.
foreveryoung001 is offline
post #4 of 9 Old 03-29-2014, 06:22 PM
EvolutionXJ
EvolutionXJ's Avatar
1994 XJ Cherokee
I am not positive if this applies to the 99' Cherokee. But on my '94, you can put the key in, and go on, off, on, off on. And your check engine light will blink. It will blink x number of times, short pause then some more. Count the blinks. If you get 1, pause, 2. Your code is 12. In between each code, there will be a long(er) pause to let you know it is starting a new code. Finally when it is done, it will throw code 55. Which means that is the end. Then google jeep cherokee check engine code list and let us know what you find, or if this works for your vehicle
EvolutionXJ is offline
post #5 of 9 Old 03-29-2014, 09:06 PM
scupking
Most likely the crank position sensor. I would also replace the IAC (idle air control). I had a 94 cherokee that would randomly die. After replacing the iac,tps and cps all was good.
scupking is offline
post #6 of 9 Old 03-30-2014, 06:16 AM
tjwalker
tjwalker's Avatar
Unfortunately, that technique won't work for a 99. That luxury went away mid-year 1997. For a 99, will need either a code reader or a scan tool, or take it to a parts store like Autozone where they will read the codes for free.
tjwalker is offline
post #7 of 9 Old 03-30-2014, 06:26 AM
jeepguy03
Winning
jeepguy03's Avatar
Most likely your crank position sensor is beginning to fail, but hasn't failed completely. Right now you are experiencing an intermittent loss of spark. Your fuel pump is probably fine. Once the crank sensor completely fails, you won't be able to start the Jeep.
I would buy the sensor from the Jeep dealer (best quality) and replace it yourself. You can do it with a socket, a few extensions, and the help from this forum.
0331 head swap DIY:
"Build" thread:
Previous: 1990 XJ Limited, 2000 XJ Sport, 2000 XJ Sport
Current: 1998 Wrangler Sahara
jeepguy03 is offline
post #8 of 9 Old 03-30-2014, 06:55 AM
ECL
Before you spend money on replacing parts, try cleaning your various grounds. When my acted in a similar manor, I cleaned the battery ground, the battery to body ground and then followed that big ground wire from the battery down to engine block. On mine it mounts to the block using the bolts that hold the coil onto the block. It was ok but one of the other 3 ground wires there wasn't doing so well. Cleaned it all up, crimped a new ring terminal on the one wire, put all back together and it's been fine since. Been over a year now. Think cheap first - you might get lucky like I did!
ECL is offline
post #9 of 9 Old 04-02-2014, 08:52 AM Thread Starter
hippyblonde
the check engine light is not on, and I did a tune up, and the grounds are ok, I cleaned the throttle body, and the fuel pump was replaced twice because I thought it was bad, so I will try the crank sensor thanks
