HELP can't get starter to work ????? - JeepForum.com
post #1 of 6 Old 09-05-2008, 12:40 PM Thread Starter
rigidmotor
i have a 96 xj . ok went to breakfast and came out and could not get starter to work. everything fine before. turn key and all lights up with break light staying on (pulled the plug on break sensor and even jumped the conector with light going out ) all seems ok but starter not working. have a hard time getting the shifter to move from park to neutral. seems like it does not wont to shift out of park. if i fiddle with the shifter it will do so but not like it should. yes it has a lot of miles on it. parked on the street and can't move it. Help
rigidmotor is offline
post #2 of 6 Old 09-05-2008, 04:20 PM
jeepnphreak
1989 XJ Cherokee
I had a similar problem with my 89' a section of the starter was going bad. whene the starter was in the "right" spot it worked fine, but at times it would leave you stranded. so jumping it did not work. So I got a new starter + core like $80 bones and 30 minutes and everything is good to go.
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #3 of 6 Old 09-05-2008, 08:00 PM
bushytails
If you're experiencing shifter problems, the most likely cause of your no start is the NSS or the shift linkage.
--Bushytails
bushytails is offline
post #4 of 6 Old 09-05-2008, 08:27 PM
kg4kzv
1995 XJ Cherokee
Check the ignition switch and the linkage between the ignition(lock) cylinder and the ignition switch.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #5 of 6 Old 09-05-2008, 08:35 PM
kg4kzv
1995 XJ Cherokee
Chris
Doh, you have a 96 so no linkage going to between the cylinder and switch. but there will be a shift interlock there. also check the shift linkage as Bushytails suggest.
Chris.
kg4kzv is offline
post #6 of 6 Old 09-05-2008, 09:21 PM
ehall
1991 XJ Cherokee
If you can get it into reverse, see if the backup lights come on.
I'm with the other guys, sounds like a linkage slipped.
ehall is offline
Why won't my Jeep start after new starter? (starter works, no spark??) DuaneJ XJ Cherokee Technical Forum 12 02-13-2012 02:45 PM
How does a starter work? Magus2727 XJ Cherokee Technical Forum 17 02-26-2010 11:32 PM
Will this remote starter work? Spokes XJ Cherokee Technical Forum 3 08-11-2009 07:24 PM
New Starter will not work. dwallace90 XJ Cherokee Technical Forum 0 08-13-2008 12:35 PM
Starter? Starter Relay? bills79jeep XJ Cherokee Technical Forum 16 05-10-2007 02:09 PM
