grinding noise when off gas pedal - JeepForum.com
post #1 of 17 Old 05-09-2009, 02:01 PM Thread Starter
typer1122
If i am doing 50 or so on the highway and let off the gas my jeep makes a grinding humming noise.. I already replaced the U joints in the driveshaft and changed the rear end fluid and neither helped does anyone have any other ideas of what i can change??? Thanks
typer1122 is offline
post #2 of 17 Old 05-09-2009, 02:42 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would give the axle u-joints and unit bearings a good look over.
xjfever is offline
post #3 of 17 Old 05-09-2009, 04:19 PM Thread Starter
typer1122
It sounds like it is coming from the back tho... I also have a nasty wobble at 50 mph when braking .. Any ideas
post #4 of 17 Old 05-09-2009, 04:29 PM
thisdothack
Not trying to threadjack, but I have the exact same problem, 2001 cherokee. The scraping/grinding/whirring sound can be heard any time the jeep is moving over 10-15mph or so for me though, and its definitely a noise from a rotating part because the sound is sinusoidal. I am going to try and replace the dif fluid for starters, 80k on the odometer. I suspect however, it might be a problem with the shoe contacting the drum or something rubbing outside the dif maybe on the rear driver side, because I get some pull to the left especially when going highway speeds. Although this could be unrelated..
this.hack
thisdothack is offline
post #5 of 17 Old 05-09-2009, 04:41 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
may be a bad wheel bearing in the rear axle.
xjfever is offline
post #6 of 17 Old 05-09-2009, 06:18 PM
Rollin
Rollin's Avatar
How high is your Jeep lifted? You could just need a TC drop to straighten out the driveline, because it sounds like your driveshaft is binding
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #7 of 17 Old 05-09-2009, 07:15 PM
cheesehead
3 words. Slip yoke eliminator. Had the same issue only after a small lift. Installed SYE and all is well again now.
cheesehead is offline
post #8 of 17 Old 05-09-2009, 07:31 PM
xxxflhrci
xxxflhrci's Avatar
If it's humming or whining when you let off the gas, my money is on your pinion bearing going out....I've had it happen twice in two different vehicles.
xxxflhrci is offline
post #9 of 17 Old 05-09-2009, 08:15 PM Thread Starter
typer1122
Thanks for all the feedback! The jeep currently has the 2 inch rubicon express kit installed So should i order the slip yoke eliminator kit and see if it helps??
post #10 of 17 Old 05-09-2009, 08:43 PM
keepishop
keepishop's Avatar
1989 XJ Cherokee
How long can you drive with a bad pinion bearing? I have two bad ones I'm expecting to die any day now.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #11 of 17 Old 06-12-2009, 01:28 PM
4X4XJJeep
4X4XJJeep's Avatar
I seem to have this simular problem. I just replaced the rear DS U joints to see if that would help. It seems like it's a little better but when I let off the gas at higher speeds it it more noticable. It is a weird noise, grinding, whirling. Anyone else have any issues like this?
"What I've want is what I've not got What I need is all around me" DMB
4X4XJJeep is offline
post #12 of 17 Old 06-12-2009, 05:55 PM
gotMoxie
gotMoxie's Avatar
2018 JK Wrangler
I've got what sounds like the same issue. I only hear it when the driveshaft has no tension on it. So only when not accelerating or deaccelerating. Noise is scary when going above 60 but barely noticable at lower speeds.
Jeep is a 96 with the 3.5" RE superflex. My money is on needing a sye just haven't got around to it yet.
gotMoxie is offline
post #13 of 17 Old 06-12-2009, 07:19 PM
keepishop
keepishop's Avatar
1989 XJ Cherokee
Noise seemed to get worse as my dana35's pinion got worse. Replaced it with an 8.25 and the noise is completely gone.
So for me at least, it had nothing to do with my driveline ujoints or lack of sye.
Bleed or Quit.
post #14 of 17 Old 06-17-2009, 08:31 PM
4X4XJJeep
4X4XJJeep's Avatar
Is it possible that the noise could be coming from the transfer case?
post #15 of 17 Old 06-17-2009, 11:42 PM
keepishop
keepishop's Avatar
1989 XJ Cherokee
It's possible. Check your tcase outputs for wobble.
Bleed or Quit.
Clutch grinding when pedal is pressed cncking2000 XJ Cherokee Technical Forum 18 10-14-2009 07:47 PM
funny gas pedal noise CG98XJ XJ Cherokee Technical Forum 2 04-06-2008 05:28 PM
Drivetrain noise - grinding and whooping noise (like curly from 3 stooges) kellen XJ Cherokee Technical Forum 1 03-06-2008 04:24 PM
New Odd Noise.....From Brake Pedal Of All Places!!! cj7jeeps XJ Cherokee Technical Forum 4 08-31-2007 09:13 AM
It's talking to me again (New noise) Grinding noise when stopped (5-speed) Junker XJ Cherokee Technical Forum 7 11-03-2005 10:51 AM
