Gas Tank Pressure - JeepForum.com
post #1 of 9 Old 06-02-2020, 08:39 AM Thread Starter
dd123c5
Gas Tank Pressure
I got a 97 Sport, and whenever i screw the gas cap on at all and have any less than a full tank an immense amount of pressure starts building up, so as when i remove it its like a reverse vacuum. I already tried to replace the gas cap, and the only other thing else i can think to replace is the gas tank vent hose, but i cant do that myself so i just wanted to make sure there wouldn't be anything else i could try before getting the whole gas tank removed.
dd123c5 is offline
post #2 of 9 Old 06-02-2020, 10:30 AM
jtec
jtec's Avatar
2014 JK Wrangler
I would suspect there would be EVAP system codes, did you scan for codes?
Are you sure it is pressure and not under vacuum ? Both would be an air rushing sound,
jtec is offline
post #3 of 9 Old 06-02-2020, 12:16 PM Thread Starter
dd123c5
The check engine came on one time but only lasted like 10 mins and couldnt check, and yes its pressure it blows the cap off before i even unscrew it all the way
dd123c5 is offline
post #4 of 9 Old 06-02-2020, 07:56 PM
jtec
jtec's Avatar
2014 JK Wrangler
look at the vent line, from tank to EVAP canister under hood - is this line plugged?
jtec is offline
post #5 of 9 Old 06-03-2020, 04:00 PM
PimaXJ
1997 XJ Cherokee
Canister fires are not unheard of, caused by gasoline reaching the canister. Often caused by overfilling & not stopping when the pump first clicks off. There is a filter on the canister as I recollect. Do be careful!
PimaXJ is offline
post #6 of 9 Old 06-03-2020, 07:28 PM Thread Starter
dd123c5
is there a diagram to find this cant seem to find were it is
dd123c5 is offline
post #7 of 9 Old 06-03-2020, 07:30 PM Thread Starter
dd123c5
i am not sure how this is relevant to my problem but no i do not overfill my tank .
dd123c5 is offline
post #8 of 9 Old 06-04-2020, 07:44 AM
jtec
jtec's Avatar
2014 JK Wrangler
pressure is unusual - guessing it may be heat expansion - the tank vents thru the line to the canister which stores fumes. The PURGE valve will send the fumes to engine when PCM commands purge.
The engine is STOCK the canister is there - no plugged lines?
Look at the emission decal (if still there) to help ID Evap lines...
Do you have any issues refueling - nozzle kicks off often?
jtec is offline
post #9 of 9 Old 06-04-2020, 05:55 PM Thread Starter
dd123c5
nope fuels up just fine, kinda the main reason why it this its the vent from the tank
dd123c5 is offline
