fuse panel Diagram 96 XJ - JeepForum.com
post #1 of 3 Old 10-24-2006, 05:15 PM Thread Starter
hansgraf
2012 MK Patriot
I have a 96 XJ I just bought
The lights on the A/C control module are not lighting up . Is there a fuse controlling this and possibly the cigarette lighter as well .Unfortunately I did not get the owners manual with it. I would be grateful if someone would list the fuses by number on the panel
Thanks
hansgraf is offline
post #2 of 3 Old 10-24-2006, 05:46 PM
kencaz
It's tied in with the dash circuit. So unless all your dash lights are out, it's just the bulb behind the panel.
KC
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #3 of 3 Old 10-24-2006, 05:49 PM
madrabbitt
madrabbitt's Avatar
yeah, if its JUST that panel thats not lit its a simple bulb replacement.
type 74 bulb.
Cig lighter out is likely a wiring issue, since its on the same fuse as the radio.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
Need fuse panel diagram SEMPER1GUMBY XJ Cherokee Technical Forum 1 02-20-2009 08:27 PM
1998 XJ Fuse Panel Diagram? coores14 XJ Cherokee Technical Forum 2 01-22-2008 01:09 PM
Fuse panel diagram nkeever XJ Cherokee Technical Forum 5 07-02-2007 05:53 PM
"00 XJ Fuse Panel Diagram Mikepags XJ Cherokee Technical Forum 4 05-30-2006 10:03 PM
97 Fuse Panel Diagram Needed Alan & Tanya C. XJ Cherokee Technical Forum 1 05-04-2006 05:28 PM
