Fuse panel diagram - JeepForum.com
post #1 of 6 Old 08-13-2006, 06:56 PM Thread Starter
nkeever
Guest
Fuse panel diagram
I am looking for the fuse panel diagram for my 2000 jeep Cherokee. Anyone know where I can get one. Thanks.
The problem I am having is that I can not lower my passenger widows for the passenger sets, but I can from the driver sets. The button on the passenger sets for the window is not lit up but the lock is.. Anyone have any ideas I would appreciate it.
nkeever is offline
post #2 of 6 Old 08-13-2006, 08:44 PM
OBXJ
OBXJ's Avatar
i just ran into the same problem today. I could control each window in the jeep from the drivers seat but not from any of the switches at the particular window. After a little bit of trouble shooting,, it turns out that the "window lock" button was shot. i simply jumped a wire inside the door panel to bypass the window lock. let me know if you need more information on how to do this... its really quite simple once you figure out which wires to jump.
2003 Jeep WJ Limited - Stock DD
1998 Jeep XJ - 4.0L, AX-15, Np231, Chrysler 8.25 rear, Dana 30 front, RE 4.5", 305/70R16 BFG MT's, 16" Cragar Soft 8's, OBA, Bushwacker Flares, AA SYE, CRC Custom DS, RE Gen2 Disco's, OME Nitro's, IPF H4 Headlights, Hella 500 Driving Lights, Factory Overhead Console, Surco/Yakima Roof rack, Hidden Hitch, K&N Apollo Intake, AirFlow Snorkel, AirRAID TBS, Alpine head unit with Sirius Module, sealed & hydroblocked.
OBXJ is offline
post #3 of 6 Old 08-13-2006, 08:51 PM
OBXJ
OBXJ's Avatar
just fyi, before you go digging for blown fuses. ALL of the power to the passenger and rear windows is supplied from the Window Lock feed on the drivers door. Im sure that's where your problem lies.
On the back of the Drivers side switch panel, you have two connectors laid out like the following:
run a jumper between the wire attached to pin 8 on C1 and the wire attached to pin 9 on C2. hope this helps.
OBXJ is offline
post #4 of 6 Old 08-15-2006, 08:29 AM Thread Starter
nkeever
Guest
thanks
thanks for your help i will look into this and see what i find.
nkeever is offline
post #5 of 6 Old 08-16-2006, 12:38 PM
Mud Machine
Mud Machine's Avatar
Check this out......
https://www.jeepforum.com/forum/showthread.php?t=288655
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS/6.0, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #6 of 6 Old 07-02-2007, 05:53 PM Thread Starter
nkeever
Guest
Still need fuse box diagram
any one have the fuse box diagram?
thanks
nkeever is offline
Need fuse panel diagram SEMPER1GUMBY XJ Cherokee Technical Forum 1 02-20-2009 08:27 PM
1998 XJ Fuse Panel Diagram? coores14 XJ Cherokee Technical Forum 2 01-22-2008 01:09 PM
fuse panel Diagram 96 XJ hansgraf XJ Cherokee Technical Forum 2 10-24-2006 05:49 PM
"00 XJ Fuse Panel Diagram Mikepags XJ Cherokee Technical Forum 4 05-30-2006 10:03 PM
97 Fuse Panel Diagram Needed Alan & Tanya C. XJ Cherokee Technical Forum 1 05-04-2006 05:28 PM
