Fuel tank vent line part number? (roll over valve line) - JeepForum.com
post #1 of 5 Old 10-01-2017, 08:20 PM Thread Starter
mystangt
Trying to resolve a P0456 code on my 2000 XJ, but Im having a very difficult time locating a replacement hard line or at least the correct MOPAR part number. Its the hard line that runs from the roll-over valve to the charcoal canister. Mine rotted through and the rubber pieces on both ends are not looking good.
Does anyone know where i can buy a replacement? Part number by any chance? I need the rubber connectors as well as the line itself.
I appreciate any and all help!
mystangt is offline
post #2 of 5 Old 10-02-2017, 01:44 PM
monkeyhouse
Rollover Valve - evap canister vent line
I don't have a part number, but I had to order brake lines for my 99 XJ. I ordered them from SSTubes. I also found that line from them. Unfortunately, I ordered it over the phone, so I don't have that part number with me. I can check when I get home and see what the number is though, if that helps. They make good stuff, but it's a little expensive because it's pre-bent. They are in Ohio too and my parts showed up quickly to Maryland.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #3 of 5 Old 10-02-2017, 09:48 PM Thread Starter
mystangt
It would be very helpful if you could check for that part number. I really appreciate it!
mystangt is offline
post #4 of 5 Old 10-03-2017, 08:54 PM Thread Starter
mystangt
I may have found the exact replacement, with the rubber grommet and all. Ill pick it tomorrow, so if its right, ill post the part number. Stay tuned.
mystangt is offline
post #5 of 5 Old 10-05-2017, 10:37 PM Thread Starter
mystangt
FOUND IT! The Mopar parts catalog has the wrong photo for it, but it is indeed part number 52100162AE. It comes with the rubber connector for the charcoal canister too. Only $20.35
I hope this helps someone fix their P0456 or similar. FYI, when I removed mine, it came up with P0455 which i assume would be the case if yours broke in half.
4351757F-ADF8-4DF4-AC76-749EAEABE193_1507261022937.jpg   81EEA0B7-0DA3-48FF-B1B2-B2EEB2B1E764_1507261037790.jpg
mystangt is offline
