Fuel Pump Noise? - JeepForum.com
 1Likes
  • 1 Post By jtec
post #1 of 7 Old 07-08-2021, 09:01 PM Thread Starter
axlaxl
Fuel Pump Noise?
So tldr had a catastrophic muffler failure. New muffler installed by shop, went home and crawled under to inspect work with engine running. All looked good, but, I noticed there was an audible humming noise from gas tank. Presuming this was the fuel pump, is that normal to be able to hear it while at idle and laying underneath it?
Just curious.
axlaxl is offline
post #2 of 7 Old 07-08-2021, 11:52 PM
jtec
jtec's Avatar
2014 JK Wrangler
you can hear them esp when tank is low... never under 1/4 tank is CW.
Wyo likes this.
jtec is offline
post #3 of 7 Old 07-09-2021, 07:25 AM Thread Starter
axlaxl
ty sir, good to know
axlaxl is offline
post #4 of 7 Old 07-12-2021, 05:01 AM
Shonic
Not quite agree, the fuel pump shouldn't be heard. Especially if it's loud.
Shonic is offline
post #5 of 7 Old 07-21-2021, 10:37 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
They do hum but you hear it clearly only at start, when they are pressurising the lines. After that you have to get real close to hear it. they are rubber isolated so you cannot detect the vibration from the fast spinning vanes inside it.
If you can hear it at idle you may want to check the mountings.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #6 of 7 Old 07-31-2021, 10:59 AM
rhythmrocker
rhythmrocker's Avatar
Originally Posted by BagusJeep View Post
They do hum but you hear it clearly only at start, when they are pressurizing the lines. After that you have to get real close to hear it. they are rubber isolated so you cannot detect the vibration from the fast spinning vanes inside it.
'88 Jeep XJ owner here who had a failed fuel pump out in the desert (115 degrees). They do hum a bit at start up (actuating). But when you hear a slightly hi-pitched hum when the truck is running, that means its failing. It's a relatively easy fix. I got one at O'Reillys and took it to a shop in Las Cruces, New Mexico, They didn't even have to drop the tank. A few hours later I was back on the road. The pump cost me about 70.00. Labor about 250.00. Replace it = peace of mind.
rhythmrocker is offline
post #7 of 7 Old 08-02-2021, 08:58 AM Thread Starter
axlaxl
So update on this, I crawled under the Jeep while it was idling, noticed I could only hear the fuel pump with my ear literally an inch away from the fuel tank in one spot, so I'm not overly worried, may get it swapped out next time I take it to the mechanic.
axlaxl is offline
