Front Sway Bar - JeepForum.com
post #1 of 3 Old 03-11-2019, 10:37 AM Thread Starter
dented
Front Sway Bar
2001 XJ 3.5" Old Man Emu lift. I have had it aligned. Rides true.
The sway bar was rubbing against the track bar bracket. I noticed Disconnects are off. The sway is being pulled passenger side. I'm not sure what is off. The trackball is adjustable and I have centered the axle.
What should I be looking for?
dented is offline
post #2 of 3 Old 03-11-2019, 11:08 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
This can happen depending upon the track bar bracket design. If the sway bar bushings are loose, the sway bar can shift slightly from side to side.
The sway bar disconnects have the sway bar end pointing up about 10 ?
If it is not causing massive damage, it will be fine as is.
CJ7-Tim is offline
post #3 of 3 Old 03-11-2019, 11:55 AM Thread Starter
dented
I believe they are up. I will have to look at how much. The sway is down across the front. I'm about to change replace the axle so I want to address everything.
dented is offline
rear anti sway bar for a 1976 CJ5 78cj5123 Jeep CJ Forum 6 11-15-2018 06:14 AM
Front sway bar links: Inside or outside of sway bar? Th0r WK Grand Cherokee & XK Commander Forum 0 04-16-2018 09:06 AM
Addco sway bar has been hitting my skid plate. Does the plate need to be repainted? moorecha19 WJ Grand Cherokee Forum 2 02-14-2018 06:50 AM
Sway bar disconnect opinons wanted JimSmith TJ Wrangler Technical Forum 15 02-06-2018 07:10 PM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
