front end grinding???????? - Page 2 - JeepForum.com
post #16 of 19 Old 02-12-2016, 08:57 AM
bluejunior
bluejunior's Avatar
Originally Posted by dailydriver88 View Post
no lift. ...yet....i got all my stuff for a 3" lift b ut dont wanna put it on till this is figured out.....
right now truck is 100% stock
Hmmm....take a real close look at your track bar and it's bushings and bracket then. That's what's responsible for the left/right centering of the axle. Any creaks or pops while turning? That's a common symptom of a cracked bracket or bad bushing there. If everything looks good I suppose it's possible it was replaced with a shorter one from a crap brand or something. Kind of like Moog's is actually a little too long.
Also double check your eyeball with a measuring tape. Distance from the inside of the rim to the frame if nothing else, but there are some better options if you feel like searching.
Lifted, Locked, Stiffened
bluejunior is offline
post #17 of 19 Old 02-12-2016, 11:42 AM Thread Starter
dailydriver88
no noises. pretty quiet lil truck. nothing while turning, bumps, nothiong at all
just notices my steering stabalizer is blown, making noise on way to work and now its squirting out fluid. .....but thats a different issue.
J-RIP
dailydriver88 is offline
post #18 of 19 Old 02-12-2016, 12:29 PM
bluejunior
bluejunior's Avatar
Not critical. A well adjusted steering setup doesn't actually NEED a stabilizer. It's just there to cover up wear and provide a little wobble control when maintenance is let go.
post #19 of 19 Old 02-12-2016, 01:05 PM Thread Starter
dailydriver88
ive only had the truck for a few weeks and im finding maintnece in some areas has been looked past by other owner.
just leaves me more time to play with the truck haah
J-RIP
differential , grinding noise , transfer case
