Front End clunk noise front axle. - JeepForum.com
post #1 of 3 Old 11-12-2019, 07:46 PM Thread Starter
bobgto
Have front end clunk noise and found out that when you hit the brakes in reverse you can see the front axle\drive shaft twist down. I was thinking the lower control arms bushings or can it be the upper control arm bushings? Or should just replace them both. Also I have tiny bit of play with yoke where goes into axle, what amount is normal? Hope axle movement has not messed up the bearing when the yoke slights into axle. Opinions ?
bobgto is offline
post #2 of 3 Old 11-13-2019, 12:19 PM
Comanche9197
Id check both upper and lower bushings n prob replace them. Your pinion bearing should be ok as your driveshaft is a slip yoke type
Comanche9197 is offline
post #3 of 3 Old 11-14-2019, 12:45 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
I had a similar problem and my upper bushings that are pressed into the axle side were completely shot with very little rubber left. For the other ones, complete stock control arms with bushings run about $20-25 each. Check your u-joint play too. It should have zero side to side movement, but will turn back and forth slightly.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
