Frame Stiffeners - JeepForum.com
 5Likes
  • 1 Post By dented
  • 1 Post By BagusJeep
  • 1 Post By dented
  • 1 Post By jserna
post #1 of 13 Old 04-10-2019, 03:59 PM Thread Starter
dented
Frame Stiffeners
Anyone with any experience?
IRO looks to have the most complete set, but as I am very interested in the center RuffStuff looks to have the best center piece.
Any opinions?
Jakegrovephoto likes this.
dented is offline
post #2 of 13 Old 04-11-2019, 11:23 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Both appear to be Z shaped stiffeners, which will work OK for the centre section if welded on correctly. Some people use L section in this location, I suppose the extra fab would make it a better connection.
The Ruffstuff is only the centre section rails, the rockers need extra work as well.
You may also want to look at stregthening the floors, it is very thin metal and even a little rust will weaken these stiffeners.
Overall the IRO set is OK and good value, it will save you time making your own and is as good value as you will get. Still leaves a tremendous amount of welding but it will get you off to a good start.
Kolak likes this.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #3 of 13 Old 04-12-2019, 02:00 AM
Kolak
Vendor
Kolak's Avatar
What I can say is that I've sold numerous sets of the IRO stiffeners to customers and have had nothing but great feedback. It's a lot of work for sure, but a very worthwhile upgrade since as you know, the XJ uniframe is rather flexy
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #4 of 13 Old 04-12-2019, 10:22 AM Thread Starter
dented
I just installed IRO 3 link. I don't like that the front axle and crossmember all land on the same 3 bolts in the unibody. The unibody was not made for it. I see it as serious weak spot. My plan is a frame stiffener on the bottom then go through the floor and cut into the frame to add a plate with nuts welded to it. I will put bolts through the 3 link brackets, through the stiffener, through the unibody (flimsy), through my plates and into the waiting nuts on the other side.
I know it will be much stronger, but I also think it will distribute the road bumps along the frame better. I'm OK for now. I just put in 4.88s in the front. Until I do the back, no 4wd. It's a real Mall Crawler at the moment.
dented is offline
post #5 of 13 Old 05-04-2019, 09:21 PM
runningonempty
Do frame stiffeners have to be welded or can one substitute bolts and nuts?
runningonempty is offline
post #6 of 13 Old 05-04-2019, 09:32 PM
paulhead
if it works fix it
paulhead's Avatar
welded and it's an endeavor (note sig). Never heard of bolt on
Trying to weld has honed my grinding skills
paulhead is offline
post #7 of 13 Old 05-05-2019, 08:49 AM Thread Starter
dented
To make them effective you would have to put a bolt every couple of inches and that would put so many holes in the frame it would be detrimental. They need to be welded.
My plan is to put them front to back, welded. I think it will be a huge improvement it ride quality and performance of ever kind. By it's design the Cherokee has lots of flex to it. After all these years it has a lot more. Add in the upgrades of suspension and bigger wheels the leverage they have on the frame (not a true frame) is way beyond what it was built to handle.
slickrocksteve likes this.
dented is offline
post #8 of 13 Old 05-05-2019, 09:32 AM
jserna
1987 YJ Wrangler
I have the stiffeners from T and J performance on my wife's 98 XJ, and they have worked great.
dented likes this.
jserna is offline
post #9 of 13 Old 05-13-2019, 01:11 AM
4x4jeepmanthing
Are the upper Z portions intended to be welded into the floor boards?
I'm in the same boat looking for a pair. Thinkin hooligan front, maybe center or ruff stuff center pending the added z effectiveness. Floor is crazy thin for welding.
4x4jeepmanthing is offline
post #10 of 13 Old 05-13-2019, 09:13 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Floor is crazy thin for putting your feet on. I keep the carpet for stability.
paulhead likes this.
post #11 of 13 Old 05-13-2019, 10:38 PM
2oldjeeps
actually pretty tough if not rusted away...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #12 of 13 Old 05-14-2019, 12:14 PM
4x4jeepmanthing
Could you please clarify what you mean by welded on correctly and the rockers needing extra work?
post #13 of 13 Old 05-19-2019, 07:01 AM
4x4jeepmanthing
Bump
ADVICE NEEDED on LJ Frame Rust sdjp General Jeep & Off-Road Equipment 3 11-24-2018 05:13 AM
Rust Proofing bare frame mikewiz38 YJ Wrangler Technical Forum 21 08-01-2018 12:19 PM
94 YJ restoration/ rebuild MigMan1313 YJ Wrangler Technical Forum 45 06-11-2018 08:24 AM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
Installing a YJ windshield frame on a CJ write up only in a jeep cj Jeep CJ Forum 14 11-15-2015 05:59 AM
