Fork Shift Rod - JeepForum.com
post #1 of 10 Old 07-08-2006, 08:15 PM Thread Starter
hmmhoyhoy
Fork Shift Rod
I know I didnt cut enough for my SYE so I will cut it a little more, would this cause it to not be able to go into anything 4wd wise? I have been stuck in between 2H and 4H and when I try to shift back it hits and then I have to manually push it back with a screwdriver.
95 YJ
4.0 AX-15
Dana 60 f with ARB 10.25 r and open. 5.13s
37" BFG AT's
02 WJ Overland
hmmhoyhoy is offline
post #2 of 10 Old 07-08-2006, 09:28 PM Thread Starter
hmmhoyhoy
Bump, anyone I cant drive my Jeep until I fix this
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #3 of 10 Old 07-08-2006, 10:18 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If you disconnect the linkage and manually shift the TC into 2wd and ity lets you, it's the linkage. If it won't go into 2wd even with the linkage disco'd it's the rod.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 10 Old 07-08-2006, 10:24 PM Thread Starter
hmmhoyhoy
Ok great thanks Balloo, I will check it all bright and early tomorrow morning, whats the best way to disconnect the linkage?
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #5 of 10 Old 07-09-2006, 12:05 AM
Jeepin_XJ_101
Right there at the nut, the pic is sideways
"When in doubt... Floor it"
1989 XJ 4.0L I6 -
- NP231 - 4" RC - 33x13.50 MT Claws
*SOLD*
2005 WK 4.7L 3.5" RK, 255/75R17 on Rubi Wheels
1992 YJ 4.0L 5" ProComp on 35x12.50 Trxus MT
Jeepin_XJ_101 is offline
post #6 of 10 Old 07-09-2006, 12:17 AM Thread Starter
hmmhoyhoy
Great! Thanks Jeepin_xj_101 LOTS of help
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #7 of 10 Old 07-09-2006, 03:16 AM
conrasm
conrasm's Avatar
Some shift rods varied in length. I didn't have to trim mine when I did my SYE. I think mine protruded about 3/4" or so and if I remember correctly, the PORC SYE had a pocket about 1 1/8" deep. It protrudes the farthest in 4LO, but if you're having problems going from 2wd to 4wd HI, you may have some problems with the linkage.
Did you have a TC drop on before you did the SYE? And did you ever adjust the linkage before (like with the drop on). The bushings on the linkage can also wear and get sloppy over the years. The rebuild kit is a couple $$ from the dealer, but it's a pain to put the new bushings in.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #8 of 10 Old 07-09-2006, 08:09 PM Thread Starter
hmmhoyhoy
I didnt mess with the linkage so I dont know if its been replaced. The shaft was cut today and that seemed fine, but my shifter {4wd} is still doin the same thing and it wont go all the way back.
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #9 of 10 Old 07-09-2006, 09:44 PM
Jeepin_XJ_101
So there is probably something up with the linkage, it would shift gears and all, but the handle placement would be all off. For example 2wd=4HI, 4LO=N and there was no room to move it into 4LO. It was just dumb and before we could figure it out I had to be somewhere and had to leave the Jeep. Also the oil pump kinda fell out of position, but barely, not sure if thats gonna pose a problem or not, it didnt seem to wanna stay. What doesnt make sense is that the linkage was fine before the install, so somethin must have happened, but we are not sure what.
1989 XJ 4.0L I6 -
*SOLD*
post #10 of 10 Old 07-09-2006, 09:55 PM
Jeepin_XJ_101
Here I have a feeling this might help out your linkage problem
1989 XJ 4.0L I6 -
*SOLD*
Can i Pickle Fork these apart? Jeep89JV XJ Cherokee Technical Forum 5 01-29-2010 05:55 PM
4wd Questions Driveshaft, Shift Fork ridebmxfbm XJ Cherokee Technical Forum 16 01-16-2009 05:57 PM
is the cast iron shift fork really that much better? RavenCorax XJ Cherokee Technical Forum 2 01-13-2009 10:19 AM
That popping was a tc shift fork CraigAllen XJ Cherokee Technical Forum 0 09-19-2008 11:51 PM
Shift fork shortening? jeepnphreak XJ Cherokee Technical Forum 3 06-16-2008 09:55 PM
