Engine "threw a rod" means... - JeepForum.com
 2Likes
  • 1 Post By Mrtoyou
  • 1 Post By jtec
post #1 of 10 Old 01-20-2020, 03:37 PM Thread Starter
car6car
deleted. Jtec didn't like the thread (post #10)
deleted.
04 Grand (dead)
car6car is offline
post #2 of 10 Old 01-20-2020, 05:12 PM
Mrtoyou
Mrtoyou's Avatar
And you call yourself a mechanic? It is also what happens when you spray starting fluid in an engine rather than actually correcting a problem. Please stop giving advice, you clearly have no idea what you are talking about.
uptillnow likes this.
If I have to explain it, you probably won't understand anyway!
Mrtoyou is offline
post #3 of 10 Old 01-20-2020, 07:03 PM
Fourspeedman
Fourspeedman's Avatar
This is for all those that mistakenly thought this was a serious thread. It all begins with the oil not lubricating the babbit bearing. There needs to be a thin film of oil separating the connecting rod bearing surface from the crankshaft. When that oil film fails the crankshaft journal touches the bearing, creates heat, and grabs it. That causes the tiny locating tabs on the bearing babbits that hold them in place on the rods to break free. It usually spins along with the crankshaft but sometimes it sticks to the rod. Now that spot is a huge oil leak. Every time that cylinder fires the rod knocks against the crankshaft. That is the knocking sound that means your engine is skewered. Dumping STP in will quiet it as will keeping rpm's very low. Now the engine must come apart. If you do not stop operating the engine it will not wait and will come apart for you- often with a rod breaking and crashing into other expensive parts. Like the block. Now, you have "thrown a rod". JB WELD will not fix it and no one welds a block after that.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #4 of 10 Old 01-20-2020, 07:31 PM Thread Starter
car6car
As far as I know iron blocks are not repairable, my Mazda block was aluminum and welding shop, which did the job, repaired them on regular basis.
04 Grand (dead)
car6car is offline
post #5 of 10 Old 01-20-2020, 07:36 PM Thread Starter
car6car
do you know somebody who killed engine by spraying starting fluid? I used starting fluid many times, never had a problem.
I call myself "kind of mechanic" because i don't fix cars for people.
04 Grand (dead)
car6car is offline
post #6 of 10 Old 01-20-2020, 07:48 PM
Michaelj51
Thanks for that!!
Michaelj51 is offline
post #7 of 10 Old 01-20-2020, 08:20 PM
Fourspeedman
Was it some kind of rare block? Because taking it apart to fix the crank and whatever broke out the side then welding it closed seems like a lot of work when junkyard engines are available. I once spun a bearing in the middle of winter. I dumped two cans of STP in and then I limped to work keeping it under 1500 rpm so it would not knock. I grabbed a Pontiac 400 out of a junked GTO, cleaned it up, and over a long weekend swapped it in time for work Monday. I calculated the effort and amount of money to fix the spun bearing to be way more than that of the junkyard engine.
post #8 of 10 Old 01-21-2020, 09:41 AM Thread Starter
car6car
Was it some kind of rare block?.
mazda 2.3 engines die all the time and pretty expensive from junk yard.
04 Grand (dead)
car6car is offline
post #9 of 10 Old 01-25-2020, 08:54 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What kinda Jeep has a Mazda 2.3 in it ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #10 of 10 Old 01-25-2020, 09:07 AM
jtec
jtec's Avatar
2014 JK Wrangler
CJ7-Tim likes this.
jtec is online now
