Engine swap - JeepForum.com
post #1 of 8 Old 05-03-2021, 06:03 AM Thread Starter
BigEd353
BigEd353's Avatar
Engine swap
I'm planning to replace the 2.5 4 banger 5 speed in my 89 xj to 4.0 automatic I bought a99. Running and driving 99 DJ for this project.
But recently someone told me I would have to swap all the whole wiring
harness ahead way to the taillights can anyone tell just what all has to be changed out PLEASE ant thanks
BigEd353 is offline
post #2 of 8 Old 05-03-2021, 07:17 AM
superj
superj's Avatar
from a 99? you will have to change lots of stuff because 99 is obd2 engine management and 89 is barely past carbureted. as far as the light harness, i have no idea if it needs to be changed but it sounds weird if it does
the xj is the only jeep left in the driveway
superj is offline
post #3 of 8 Old 05-03-2021, 10:59 AM
Fourspeedman
Fourspeedman's Avatar
Yes, as SuperJ said- OBD2 is in charge. Everything will need to be swapped. All sensors, all wiring, maybe even the tank mounted fuel pump if '89 didn't use one. The trans is electronically shifted too. The good news is that emissions engine management systems are usually separate from the rest of the car systems like lighting. But I know that on my '00 and '01 a LOT of body systems like AC, dash gauges, etc, ARE managed by the PCM. But you should be able to separate the engine systems wiring from the rat's nest of front end wiring and leave the original stuff alone. I don't know what state you live in but in many, you must pass emissions inspection for the year of the engine- not the body. Unless you can sneak it on by. Wink wink, nod nod.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #4 of 8 Old 05-03-2021, 11:58 AM
superj
superj's Avatar
yup. i would definitely do an engine management from an 89 4.0 instead of the 99. that should be lots easier
superj is offline
post #5 of 8 Old 05-04-2021, 05:16 PM
Fourspeedman
Any chance of keeping the 5 speed manual with the 4.0?
post #6 of 8 Old Yesterday, 12:00 PM
superj
superj's Avatar
i don't think you can keep that particular 5 speed. someone will have to verify but i believe the bolt pattern is different between the 4.0 and 2.5
superj is offline
post #7 of 8 Old Yesterday, 04:08 PM
Fourspeedman
Whoa- different bolt patterns? That is just so, so, JEEP!?!
post #8 of 8 Old Today, 09:08 AM
BaileyNB
1947 CJ2A
I wouldn't suggest matching the AX5 with a 4.0 regardless of it bolting up. Unfortunately, finding an AX15 isn't the easiest (or cheapest) endeavor.
BaileyNB is offline
