Driver side front wheel spins but has no power - JeepForum.com
post #1 of 7 Old 08-31-2012, 08:06 AM Thread Starter
andynowlen
Hi all, After last weekend - 1986 Cherokee - Dana 30 front axle with central axle disconnect (CAD) with DIY PosiLok - I noticed some front axle noise and that something is wrong.
I have my rig up on jack stands.
The transfer case range selector shifts normally to 4 high
The front drive shaft spins normally
The CAD DIY posilok engages correctly
The passenger side wheel spins up normally
The driver side wheel barely spins up.
When listening carefully at the driver side wheel I hear a subtle rattling 'bearingish' like sound coming from the center area of the wheel approximately.
I disassembled the driver side.
Everything appears normal.
I pulled the driver side axle it is fine. No damage visible.
The hub and bearings are nearly new and appear normal.
I pulled the cover off the front differential expecting something there, like metal in the bottom. But I find no visible broken parts, nothing in the fluid.
Is my problem inside the differential itself?
I have never worked on a differential and don't know what to expect - if that is the problem. Do you all have any advice? Is there a write up somewhere that will get me going?
Thanks in advance,
Andy
P.S. - The reason I sense a possible problem is that the way it spins now is the opposite of the way it used to spin. The driver side wheel would spin first and the passenger side second. Later today I will get to work on it.
andynowlen is offline
post #2 of 7 Old 08-31-2012, 08:09 AM
whitexj98
You have a normal operating open differential..... (unless you have a locker, then there is an issue)
98 XJ lifted/Locked/Geared
My Build: https://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #3 of 7 Old 08-31-2012, 10:34 AM
rytomi
^^^ What he said. Grab your right wheel to stop it and the left should start spinning.
Looking to buy MJ, 2.5L, 5 speed, 4x4. *PM me*
rytomi is offline
post #4 of 7 Old 08-31-2012, 05:06 PM
Diamond-x
1991 XJ Cherokee
What is a CAD DIY posilok?
Diamond-x is offline
post #5 of 7 Old 08-31-2012, 07:43 PM Thread Starter
andynowlen
This front axle has a central axle disconnect (CAD) and a do it yourself (DIY) cable pull to engage the front axle replacing the vacuum operated system which can develop breaks or leaks. (PosiLok)
post #6 of 7 Old 08-31-2012, 08:11 PM
Millermagic
Older XJs and YJs had vacuum disconnect axle shafts (2 piece). The system often messes up ... people replace them with solid shafts or a system to engage them / disengage them in a more reliable manner.
Not to be confused with posi-traction.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #7 of 7 Old 09-03-2012, 12:10 PM
Diamond-x
1991 XJ Cherokee
Thanks for the clarification
1986 , dana 30 , front differential , no 4wd
92 XJ Driver's Side Power Locks Not Working BarCow XJ Cherokee Technical Forum 1 01-29-2010 10:43 PM
Driver's side power window problem Dr Tweak XJ Cherokee Technical Forum 6 02-22-2009 11:13 AM
Driver-side front wheel clicks on hard right turns...? Nashpatr XJ Cherokee Technical Forum 2 06-21-2008 09:37 PM
Squeaking sound from front driver's side wheel/brakes insurrection151 XJ Cherokee Technical Forum 3 10-22-2007 12:49 PM
Driver side power point Ubie XJ Cherokee Technical Forum 4 03-29-2006 06:52 PM
