double din radio in the XJ? - JeepForum.com
post #1 of 21 Old 06-07-2012, 01:11 PM Thread Starter
tdp1jeep
Is it possible to install a double din radio in the XJ?
tdp1jeep is offline
post #2 of 21 Old 06-08-2012, 08:09 AM
TheNerd
TheNerd's Avatar
Not without cutting/modification. With that being said, I've seen it done.... I think on the carputer site...
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline
post #3 of 21 Old 06-08-2012, 01:56 PM
bluejunior
bluejunior's Avatar
Unless you're installing one HELL of a unit that you got for free or something, don't bother. It's SOOOOO much work for relatively little benefit. I did some research into the carputer thing awhile back, it was actually easier to put a micro-case with a 12v power supply under the rear seat and then install a lilliput 10" monitor on the bezel than it was to use one of the double-din units, because there was a lot less cutting involved. Just get a single din and the adapter plate. There are some 1.5-din units out there if you just can't stand to look at the unit in the bezel.
http://www.sonicelectronix.com/item_...DEH-P47DH.html
Lifted, Locked, Stiffened
bluejunior is offline
post #4 of 21 Old 06-08-2012, 09:33 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I'm going to use one of these when I replace my stock HU in the very near future. It should look way better than having half an inch of trim above and below the radio.
http://www.amazon.com/Metra-99-6000-...I3PLOSH5WF3OMY
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
06 KJ - Basic Transportation
dagr8tim is offline
post #5 of 21 Old 06-08-2012, 09:51 PM
chriskeenan
chriskeenan's Avatar
i just made my own mounting plate for a single din unit, moved the HU slot as far up as possible and mounted my subs remote gain and an on/off toggle and LED indicator under it. Its just some 1/8in steel bent and cut to fit, works well, even has room to mount a few more switches.
Ive played with the idea of a double din unit, its do-able in an XJ and the one in my friends JKUR is nice, but it looks out of place and it the touch screen kind of a pain to use. Im thinking about one of Fusions 700 series single din marine units for the next audio upgrade.
Not the best photo but you can see the HU and switch, the gain control is to the right and the LED to the left.
chriskeenan is offline
post #6 of 21 Old 06-09-2012, 06:24 AM
BlueRidgeMark
1994 XJ Cherokee
What he said.
BlueRidgeMark is offline
post #7 of 21 Old 06-09-2012, 05:21 PM
bluejunior
bluejunior's Avatar
@Chriskeenan: HEEEEY! A basslink! My very first system was a basslink II with the 4-Channel amp module in it, SQ and volume were impressive but the sub died on me took it apart and used the guts in a box in my little cousin's truck.
post #8 of 21 Old 06-10-2012, 03:19 AM
Scott4589
Scott4589's Avatar
2017 JK Wrangler
I just installed a touch screen double din. It took some time getting it to look good, but I am in love with it.
If you have the time and want a nice little project, then i say go for it. It is not as hard as you might think it is.
I will post a pic soon
just posted this picture, sorry i dont know how to make it smaller on the forums. but you get the idea. That little slot right below the vents..... I am going to work on making a slide out panel that will come out and hang down to cover the screen.
Scott4589 is offline
post #9 of 21 Old 06-17-2012, 11:28 PM
martinbuilt
Here i s a fairly easy way to install a 2 din unit into a 97-01 Cherokee
I'm working on building a few of these.
Martin
martinbuilt is offline
post #10 of 21 Old 06-20-2012, 04:25 PM
Tyreman
Tyreman's Avatar
Have you thought about getting a flip out single din? Pioneer makes some really nice ones.
Tyreman is offline
post #11 of 21 Old 06-20-2012, 11:47 PM
dsigned
I can't remember where I found this pic and really wish I could find a bigger better version, but I really like how they did this. Also wish I could find some company that made it being fiberglass is one thing I've never messed with.
I had a flip out in my 2000 but didn't like it which is why I'm going double din (one way or another)
dsigned is offline
post #12 of 21 Old 06-22-2012, 06:33 PM
bluejunior
bluejunior's Avatar
Good audio shops do custome enclosures and mounting, just call a few and ask. It's expensive though (200-300 dollars most places I've ever asked)
post #13 of 21 Old 06-22-2012, 09:43 PM
dsigned
For that much I think I could prob figure it out. I know idiots that know how to work with fiberglass and if they can do it I'm sure I could get it.
dsigned is offline
post #14 of 21 Old 06-28-2012, 12:01 PM
sweenepj
Thanks for the heads up on this. I never even though to look... just assumed the black bar was the only option. I got one, installed it, and it looks good plus I can stuff my remote in there.
sweenepj is offline
post #15 of 21 Old 01-27-2013, 11:12 AM
xjguy1
sweet. thats awesome martinbuild. im defiantly going to do this.
xjguy1 is offline
How to double the 231 xj_army XJ Cherokee Technical Forum 15 10-12-2015 09:54 AM
Anyone with a double din radio installed? JeepFiend XJ/MJ Cherokee Non-Technical Forum 3 12-28-2009 11:22 AM
Awesome radio reception. Antenna or radio? sparkchaser XJ Cherokee Technical Forum 20 01-16-2008 08:43 AM
single, single 1.5 or double din for the radio? CherokeeClassic XJ Cherokee Technical Forum 9 07-10-2006 09:46 PM
New radio, any one got the wiring diagram for the radio wires mnjeep XJ Cherokee Technical Forum 3 12-26-2004 05:06 PM
