D30 axle U-joint? - JeepForum.com
post #1 of 7 Old 01-17-2020, 05:13 PM Thread Starter
Mrtoyou
Mrtoyou's Avatar
D30 axle U-joint?
Is the D30 axle U-joint a 1310 series?
If I have to explain it, you probably won't understand anyway!
Mrtoyou is offline
post #2 of 7 Old 01-17-2020, 05:31 PM
paulhead
if it works fix it
paulhead's Avatar
From Naxja falcon556
* All 84-88 D30s have 5-260x u-joints (1 1/16" diameter caps)
* 1989-95 non-ABS have 5-260x u-joints
* 1989-95 with ABS have 5-297x u-joints (1 3/16" diameter caps)
* All 1995 1/2+ have 5-297x u-joints
* 5-297x u-joints can be replaced with the stronger 5-760x u-joint
Trying to weld has honed my grinding skills
paulhead is online now
post #3 of 7 Old 01-18-2020, 07:23 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
XJ Driveshaft u-joints are 1310 series.
1310 = 5-153x Spicer greaseable
1310 series measures
3.219 inches ( 3 7/32 inches ) wide in both directions
All 4 bearing caps are 1.0625 inch ( 1 1/16 inch ) diameter
Outside snap rings
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 7 Old 01-18-2020, 08:11 AM
Michaelj51
Question, out of curiosity.... Can drive shaft u-joints be changed, properly, with the TC and Differential yokes in place?
Michaelj51 is offline
post #5 of 7 Old 01-18-2020, 08:23 AM
CJ7-Tim
CJ7-Tim's Avatar
Not sure exactly sure what the question is ? Remove the driveshaft, and replace the u-joint. Depending in which end needs replacement, the drive shaft slip yoke or the double cardan joint may be involved.
- Benjamin Franklin
CJ7-Tim is offline
post #6 of 7 Old 01-18-2020, 10:04 AM
Michaelj51
Sorry Tim, Question asked before first cup of coffee or critical thinking engaged..... Disregard
post #7 of 7 Old 01-18-2020, 10:45 AM
CJ7-Tim
CJ7-Tim's Avatar
No sorry needed, it was just a bit unclear. One of my Dads favorites sayings was "Make sure brain in engaged, before putting mouth into gear".
- Benjamin Franklin
CJ7-Tim is offline
