Cruise control - JeepForum.com
 2Likes
  • 1 Post By jtec
  • 1 Post By Wallyb4
post #1 of 13 Old 07-21-2021, 05:22 AM Thread Starter
mhjo
mhjo's Avatar
Cruise control
My cruise control works only once in a while. However when I push the ON button the cruise lamp in the dash always turns on. I have replaced the vacum cannister in the engine bay.Works every 1/4 time. Checked for vacum leaks, but foun d none.
2000 Sport, K/N, 12 hole injectors, Viper Coil Mod, 62mm TB
mhjo is offline
post #2 of 13 Old 07-21-2021, 06:50 AM
jtec
jtec's Avatar
2014 JK Wrangler
some thought-
the AIRBAG light is off?
The CEL is off?
Is there 12v at the servo? DB/RD wire.
>>I suspect above is NO then
The brake switch, NOT the part of sw that turns on brake lamps, the switch supplies 12v to servo?
jtec is offline
post #3 of 13 Old 07-21-2021, 07:41 AM
Wallyb4
Wallyb4's Avatar
1997 XJ Cherokee
I would also check the cable going from the cruise controller to the throttle body. Try lubricating it so it moves freely.
Walter Ballard
97 Jeep Cherokee 4.0L
My Toy.
Wallyb4 is offline
post #4 of 13 Old 07-21-2021, 08:43 AM Thread Starter
mhjo
mhjo's Avatar
Originally Posted by jtec View Post
some thought-
The CEL is off?
That was too complicated for me (me not english speaking)
mhjo is offline
post #5 of 13 Old 07-21-2021, 09:33 AM
jtec
jtec's Avatar
2014 JK Wrangler
try google translator.
jtec is offline
post #6 of 13 Old 07-21-2021, 10:01 AM Thread Starter
mhjo
mhjo's Avatar
some thought-
The CEL is off?
Thanks for trying to assist me, Yesb the AIRBAG light is off, but
I don't know what DB/RD wire is or where it is located. I neither know what "sw" means, or the "servo" or "CEL".
mhjo is offline
post #7 of 13 Old 07-21-2021, 10:28 AM
Wallyb4
Wallyb4's Avatar
1997 XJ Cherokee
CEL = check engine light, look's like an engine.
SW= Switch
Hard to explain servo.
Walter Ballard
My Toy.
Wallyb4 is offline
post #8 of 13 Old 07-21-2021, 11:10 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The most common cause of non functioning cruise control is faulty switches on the steering wheel.
Servo is an electrical+mechanical actuator. It is the device under the hood that does the work to operate the cruise control.
Check the vacuum tube and the electrical connector. Split vacuum tubes, rotten elbow tube junctions, and damaged wires or corroded wire plugs are logical suspects.
See picture.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #9 of 13 Old 07-21-2021, 11:19 AM
Wallyb4
Wallyb4's Avatar
1997 XJ Cherokee
Also if the cable coming from the servo going to the throttle body is sticking it can effect it also. spraying some lubrication on it can help.
Walter Ballard
My Toy.
Wallyb4 is offline
post #10 of 13 Old 07-21-2021, 11:53 AM Thread Starter
mhjo
mhjo's Avatar
Thanks. No CEL.(Car is in excellent condition except for this issue). I replaced the servo.
It works perfectly when it works, but if I turn it off and on again, it's dead. After several tries it might work again. It dosn't stop working while on, only when I try to start it up again
mhjo is offline
post #11 of 13 Old 07-21-2021, 12:22 PM
jtec
jtec's Avatar
2014 JK Wrangler
Yu claim the light comes on - and it works sometimes, I suspect the brake switch. Common problem.
The servo shown above - there are 4 wires, is there 12v on the dark blue wire.
Wyo likes this.
jtec is offline
post #12 of 13 Old 07-21-2021, 11:35 PM Thread Starter
mhjo
mhjo's Avatar
OK, thanks. That is someting I have not thought about and seems sound. I will try to adress the brake switch. Is it mounted on the brake pedal?
mhjo is offline
post #13 of 13 Old 07-22-2021, 04:38 AM
Wallyb4
Wallyb4's Avatar
1997 XJ Cherokee
It should be just behind the brake pedal. Also when you press on the cruise control switches on the steering wheel can you feel some resistance or a bump while pressing down on the switch? You could need new switches in the steering wheel also.
Wyo likes this.
Walter Ballard
My Toy.
Wallyb4 is offline
