cranks but doesn't start - JeepForum.com
post #1 of 6 Old 09-04-2019, 10:38 PM Thread Starter
bradleyheathhays
bradleyheathhays's Avatar
So I got this '96 Jeep Cherokee XJ that cranks but doesn't start. It's got around 180k on her but I keep everything in good shape. Batt seemed strong.
I used to drive it everyday but this past year I've driven it only about twice a week. It's been just slightly slower to start in the last couple of months, but just barely slower. Was guessing it had something to do with aging plugs or something.
Drove it yesterday and everything was normal like always, sat overnight and today it cranked but didn't catch.
Any ideas on where to start?
~~_/) ~~
bradleyheathhays is offline
post #2 of 6 Old 09-04-2019, 11:13 PM
mukluk
mukluk's Avatar
Check for blown fuses, look under the hood and underneath to see if rodents have chewed any wiring, then turn the ignition to on/run to see if you can hear the fuel pump prime for about two seconds. From there, try to narrow the problem down to fuel or spark by spraying a shot of starter fluid down the throttle body to see if it will briefly catch or not.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 6 Old 09-06-2019, 04:33 PM Thread Starter
bradleyheathhays
Thanks mukluk that sounds like solid advice.
So far I've been able to run a couple tests..
Hooked up a fuel pressure gauge and first key turn got it up to only 20psi. Second turn got it up to 45. And third and subsequent turns got it up to 48. It only fell to 43 after 2 minutes so I think that means the fuel pressure is good.
Hooked up a spark tester between a plug and wire and it didn't light at all when cranked so I'm guessing I've got a spark problem. I'll start by doing a tune up with new rotor, cap, wires and plugs then see what happens.
~~_/) ~~
post #4 of 6 Old 09-06-2019, 05:40 PM
kadetklapp
kadetklapp's Avatar
1997 XJ Cherokee
Check fuel, check spark. Is fuel pump running? Do you have pressure at the rail? WhT kind of shape is cap and rotor in? Any check engine light prior to? Something I always do on a crank-no-start on these is unhook the battery for 20 minutes or so then try again.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #5 of 6 Old 09-11-2019, 01:40 AM
Hamid
Hamid's Avatar
If you got fuel pressure on gauge, and no spark, check the ASD relay in the distributor box under the hood, sometimes it burns.
2000 Jeep Cherokee Classic. Built for export
432K Kilos.
Hamid is offline
post #6 of 6 Old 09-11-2019, 11:10 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
^ ASD relay
It feeds power to coil, injectors etc. If you have no battery at these items, it will be because the ASD relay has not engaged. This can be for a number of reasons including bad relay, loose connectors in base, no signal from PCM. I take the relay out and check for voltage and ground on pins in base.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
