clutch fan pulley bearing. - JeepForum.com
post #1 of 9 Old 01-29-2013, 11:24 AM Thread Starter
RIjon
Damn thing is REALLY making a lot of noise and starting to wobble.
Seems like you either replace the entire bracket ($175+), or swap to an eFan ?
I'm thinking JY Taurus fan and DC controller ?
Anyone have a better idea?
Switch panels for our jeeps
2008 Toyota Tundra RCSB Supercharged
1998 Cherokee Classic ..... work in progress
RIjon is offline
post #2 of 9 Old 01-29-2013, 04:18 PM
AZ Jeff
2014 JK Wrangler
Buy a new bearing and install it yourself. AutoAirOnline has the bearing.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 9 Old 01-29-2013, 08:49 PM Thread Starter
RIjon
Do you happen to have any more info?
Part # or link?
Most every thread I have read about replacing the bearing hasn't ended well. Have you done this yourself?
Thanks
RIjon is offline
post #4 of 9 Old 01-29-2013, 09:42 PM Thread Starter
RIjon
I found the part number. NSK part.... and can be purchased at Motion Industries # 885586 .
I will attempt to fix this.
RIjon is offline
post #5 of 9 Old 01-30-2013, 10:57 AM
djb383
Dayum.....we just paid $317 for the a/c bracket/fan bearing hub assembly and to top it all off, the squeal/howl turned out to be the distributor. Duh on our part.
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #6 of 9 Old 01-30-2013, 04:40 PM Thread Starter
RIjon
That sucks djb. Is it a bearing in the distributor?
Well my pulley bearing seized up on the way home from work today. Threw the belt. It was obvious because my steering went.
I pulled over and sure enough. I had to milk it home because without a waterpump, temps go crazy REAL fast.
Ironically, I ordered the bearing today for $37, Should be 2 days. But now I am thinking I will convert to a efan and short belt anyway. I'm not even sure I can R&R the bracket anyway. Besides, I rather the jeep heat up faster and have less parasitic loss.
What is it with Jeeps and bearings?
RIjon is offline
post #7 of 9 Old 01-30-2013, 05:19 PM
djb383
Now we have an extra bracket with good bearings. I believe the distributor uses bushings vs bearings.
djb383 is offline
post #8 of 9 Old 01-30-2013, 06:27 PM
AZ Jeff
2014 JK Wrangler
If you figure out how to delete the mechanical fan pulley shaft, you will be the first.
AZ-Jeff
AZ Jeff is offline
post #9 of 9 Old 01-30-2013, 06:51 PM
djb383
I'm not even sure I can R&R the bracket anyway. Besides, I rather the jeep heat up faster and have less parasitic loss..........
Be careful when moding the factory fans.......mods may work this time of year but 5-6 months from now may be a different can of worms.
djb383 is offline
