Chrysler or Dana? - JeepForum.com
 2Likes
  • 1 Post By Devil15
  • 1 Post By GPSBob
post #1 of 13 Old 06-07-2019, 01:37 PM Thread Starter
GPSBob
2015 WK
Chrysler or Dana?
Hello all!
I recently bought my first XJ - a '97 Sport, 4.0L 5-speed, 4x4. Currently not running - appears to be a bad fuel pump (at least, could be more things...)
Another issue is rusted brake lines. It appears that you need a different set of lines depending on whether you have a Chrysler or Dana rear axle. How do you know for sure which it is?
Thanks!
GPSBob is offline
post #2 of 13 Old 06-07-2019, 03:38 PM
Devil15
Dana 35 the pumpkin is round, the 8.25 has a flat spot on the bottom.
Sent from my SM-G892U using Tapatalk
dented likes this.
Devil15 is offline
post #3 of 13 Old 06-08-2019, 09:46 AM Thread Starter
GPSBob
2015 WK
Thanks for the info! It's a Chrysler.
dented likes this.
GPSBob is offline
post #4 of 13 Old 06-08-2019, 10:53 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 13 Old 06-11-2019, 05:54 PM
kadetklapp
kadetklapp's Avatar
1997 XJ Cherokee
Then it’s the better of the two.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #6 of 13 Old 06-12-2019, 08:42 AM Thread Starter
GPSBob
2015 WK
I appreciate the help. I'm sure I'll have more questions as this project moves ahead. I'm ready to drop the gas tank to replace the fuel pump. Once I get it running, I'll see what else is in store for me...
GPSBob is offline
post #7 of 13 Old 06-12-2019, 10:37 AM
40vern
tank
depending on how long it has set up, i would replace more than just the pump.
if the tank is ok on the inside, then i would replace the pump and the sending unit together. allot of work to have to replace the pump and then later have to do it all over again for the sending unit.
40vern is offline
post #8 of 13 Old 06-13-2019, 08:53 AM Thread Starter
GPSBob
2015 WK
Yes, I'm planning on doing exactly that. I don't want to have to drop the gas tank twice.
GPSBob is offline
post #9 of 13 Old 06-13-2019, 11:58 AM
40vern
really not that bad of a job. but it can be a pain in then but. when i tried to put the big fuel line that you use to put fuel in the tank, i sprayed the hoses down with soapy water. make then slide on easier.
40vern is offline
post #10 of 13 Old 06-14-2019, 07:20 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
If the pump mounts at the front side of the tank, there's no need to drop the tank.
D3<!L!>3D
S8NNG8 is offline
post #11 of 13 Old 06-14-2019, 11:51 AM
40vern
true
my 95 is like that. i can take the sending unit out but i can never seem to get it back in. i ended up pulling the tank anyway.
just to tight of a fit and i did not feel like i had the o ring in correctly
i am getting old and cannot see as good lol
40vern is offline
post #12 of 13 Old 06-14-2019, 01:48 PM Thread Starter
GPSBob
2015 WK
My nephew's '96 also has the pump mounted on the front of the tank, but on my '97 it sits on top.
GPSBob is offline
post #13 of 13 Old 06-15-2019, 02:39 AM
40vern
thought so
i was not sure but i figured it did. this is the way my 99 is set up.
just dont cut a hole through the floor to get to it. lol saw a guy do this cause he did not want to pull the tank
40vern is offline
