cherokee stalls! please help.. - JeepForum.com
post #1 of 4 Old 06-29-2014, 09:39 PM Thread Starter
sbmuddin
1990 XJ Cherokee
i have a 1990 cherokee sport, 4.0, and it stalls when i feather the gas, (only giving it 100-300 rpms) at a stop and when reversing. i have refreshed the grounds at the dipstick, replaced and correctly adjusted tps, replaced iac, fuel pump/ filter, plugs, wires, cap/rotor, crank sensor, oil pressure switch (non related issue), added secondary ground from battery to chassis, checked/ replaced the iac relay, fuses, and tested all sensors per this article http://www.lunghd.com/Tech_Articles/...iagnostics.htm
all checked fine except the MAT (manifold air temp) sensor, but im not convinced thats causing my issue. please help. thanks!
sbmuddin is offline
post #2 of 4 Old 06-30-2014, 07:10 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I have seen loose engine to trans bolts cause that.
Auto or manual?
Have you ever done numbers 3 and 5 in my link below?
Cleaned throttle body before adjusting TPS and you used MY instructions for the "engine" side?
CPS wiring harness routed properly?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is online now
post #3 of 4 Old 07-01-2014, 06:50 PM Thread Starter
sbmuddin
1990 XJ Cherokee
The cps wiring the s the same as when I removed it, I have dropped the trans to replace the flexplate but it was doing it before that.. Could loose motor mounts cause anything? what steps are you referring to? Its an automatic. (Aw4 I believe)
Tried to think of a name for my jeep,its a pain in my a**, P.I.M.A is her name.
sbmuddin is offline
post #4 of 4 Old 07-01-2014, 09:25 PM Thread Starter
sbmuddin
1990 XJ Cherokee
Sorry I just found your link, I have checked all sensors, all are operating normal, a couple I have replaced, but I did find one bad sensor
sbmuddin is offline
cherokee , jeep , stalling
