Cherokee '89 4 Litre Auto. 4x4 high in constant use is this OK? - JeepForum.com
 5Likes
post #1 of 20 Old 05-18-2019, 03:57 PM Thread Starter
Gremmy
1989 XJ Cherokee
Cherokee '89 4 Litre Auto: Does anyone here use their Jeep XJ in constant 4x4 high everyday all day? 2WD will get you better mileage, but is there any reason why you can' select high 4x4 and go for ever? I don't have a factory user manual to check recommendations so how do you guys use your 4X4? What is the theory?
Gremmy is offline
post #2 of 20 Old 05-18-2019, 04:12 PM
2oldjeeps
cant drive on dry pavement. you will trash the t case/diffs. get a book.
only snow grass,mud,back yard...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #3 of 20 Old 05-18-2019, 05:47 PM Thread Starter
Gremmy
1989 XJ Cherokee
On a label, sun visor, says 'Any Surface High'.
Gremmy is offline
post #4 of 20 Old 05-18-2019, 06:51 PM
2oldjeeps
sorry,my jeeps dont work that way.
if its ok making turns on dry roads,ok. idk 89
Gremmy likes this.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #5 of 20 Old 05-19-2019, 05:23 AM Thread Starter
Gremmy
1989 XJ Cherokee
I don't think '4x4 high' goes through the transfer box, so might be ok, just when you engage '4x4 low' do you connect the transfer?
Gremmy is offline
post #6 of 20 Old 05-19-2019, 07:03 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Which transfer case is installed ?
4x4 Hi or 4x4 Lo means the transfer case is engaged.
The NP242 Selec-Trac was an option available in 1989 and the FullTime 4x4 position can be used on any surface at anytime for as long as you want.
4x4 Hi and 4x4 Lo are Part Time selections that can ONLY be used on slippery surfaces: dirt, gravel, rocks, snow, mud, etc. Do not use Part Time 4x4 for extended periods of time/distance on dry pavement.
fastblack likes this.
CJ7-Tim is offline
post #7 of 20 Old 05-19-2019, 10:18 AM
2oldjeeps
everything goes thru t case. crawl under and look...!!!
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #8 of 20 Old 05-21-2019, 02:31 PM
Pinoy59
1997 XJ Cherokee
Shift patter looks like this...
Sent from my SM-G955U using Tapatalk
NP242/skidplates/RC4.5"LA kit/33x12.5mudclaws/15x10rim/sliders&flares/trussed-locked8.8/winchbumper
Pinoy59 is offline
post #9 of 20 Old 05-21-2019, 05:00 PM Thread Starter
Gremmy
1989 XJ Cherokee
That's the one. Does full time 4x4 go through transfer box?
Gremmy is offline
post #10 of 20 Old 05-21-2019, 05:09 PM
Pinoy59
1997 XJ Cherokee
Yes, the difference is it's not locked front to rear like the part time 4x4. Meaning the torque can still go to one wheel.
Pinoy59 is offline
post #11 of 20 Old 05-21-2019, 05:28 PM Thread Starter
Gremmy
1989 XJ Cherokee
Thanks, what are the years of Cherokee that have FULL TIME 4 please?
Gremmy is offline
post #12 of 20 Old 05-21-2019, 05:30 PM Thread Starter
Gremmy
1989 XJ Cherokee
Are there other years of FULL TIME 4X4 or is it just 1989?
Gremmy is offline
post #13 of 20 Old 05-21-2019, 05:31 PM
CJ7-Tim
CJ7-Tim's Avatar
www.jeepforum.com/forum/f11/cherokee-stock-specs-26256/ informs us that NP228/NP229 - "Selec-Trac" - 4Hi (full-time) - N - 4Lo (part-time) - was installed 1984-87.
NP242 - "Selec-Trac" part-time OR full-time - 2.72:1 ratio low range - shift pattern 2wd - 4part-time - 4full-time - N - 4LO - was an option from 1987-2001
Gremmy likes this.
CJ7-Tim is offline
post #14 of 20 Old 05-21-2019, 05:33 PM
Pinoy59
1997 XJ Cherokee
I think they started around 87 and went through 01. You can Google NP242 to verify that. just looked at it and it is 87.
The pros of having it on the 92 and older XJ is you don't have the cad vacuum disconnect with a one piece axle shaft!
Gremmy likes this.
Pinoy59 is offline
post #15 of 20 Old 05-21-2019, 05:34 PM
Pinoy59
1997 XJ Cherokee
I have it in my 97.
Gremmy likes this.
Pinoy59 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
2000 Green Cherokee 4x4 mrsig Jeeps For Sale 4 02-21-2018 02:22 AM
Carburator switch will affect auto transmission on 1989 cherokee? tavok86 XJ Cherokee Technical Forum 2 01-28-2018 10:53 AM
1995 Jeep Cherokee Sport 4x4 4.0 Auto Intermittent shut off 1999_Jeep_TJ XJ Cherokee Technical Forum 2 01-20-2018 09:38 PM
