Changing Bolt Patterns? - JeepForum.com
post #1 of 5 Old 09-19-2006, 09:56 AM Thread Starter
cbassillo
cbassillo's Avatar
Hey, I'm looking to get a Waggy D44 front, but it's 6 lug. It's possible to change the bolt pattern right? But how hard/expensive would it be?
Female owned, built & beaten.
Charlee
"Nancy" '99 XJ: 10" lift, 37x14" Iroks - D44 front & rear, Safari Snorkle, ETC. ETC.
cbassillo is offline
post #2 of 5 Old 09-19-2006, 10:03 AM
XJH-007
XJH-007's Avatar
You can do it 2 ways,
Theres a company that sells adapter plates for different lug patterns, the problem is it will increase your axle width by 2"-4".
OR you can buy Hybrid Axle shafts with your Waggy Spline count and 5 on 4.5 lugs.
Neither is cheap.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #3 of 5 Old 09-19-2006, 10:09 AM Thread Starter
cbassillo
cbassillo's Avatar
I guess I could just buy 2 new rims, no..?
Charlee
post #4 of 5 Old 09-19-2006, 10:33 AM
XJH-007
XJH-007's Avatar
Yeah, you could do that if you wanted to deal with not being able to properly rotate your tires, and carry 2 different spares all the time.....yuck...
***02 WJ Overland
XJH-007 is offline
post #5 of 5 Old 09-19-2006, 10:46 AM
DirtyCommanche
Guest
This thread is ****ed. With a REAL D44 front, the smallest bolt pattern you can run is the ford 5x5.5. That's be done by using ford knuckles (weak) and ford brakes.
You have to get new rims, plane and simple. If you want them all to match, you've got to touch the rear...
Depending, you may be able to re-drill your current axle shafts. I wouldn't.
Anywho, I'd strongly recommend ditching the rear you have. Seeing as how you're going to get a new front end, now might be the time to go to some low gears, eh? Izusu makes an axle called the 12 Bolt - It comes factory with disk brakes, 4.56s, often a stiff LSD, a drop out third and all steel housing. It's like a 9" actually, just somewhat smaller. I'd suggest swapping one in. The bolt patten will match the waggy 6-lug.
Or, go with a toyota 8" rear. 6 lug, plenty of aftermarket, stock low gears, etc.
DirtyCommanche is offline
Vertical Bolt broke off when changing shock absorbers... XJMuscle98 XJ Cherokee Technical Forum 19 04-07-2010 10:39 PM
changing bolt ears on clutch master cylinder vicegod2003 XJ Cherokee Technical Forum 0 06-23-2009 03:25 PM
are all (jeep) bolt patterns created equally? Hummer2Rescue XJ Cherokee Technical Forum 4 06-07-2007 09:10 AM
DIY Bumper Bolt Patterns 96XJ9705 XJ Cherokee Technical Forum 11 04-28-2007 06:42 AM
rim bolt patterns ronnjonn XJ Cherokee Technical Forum 3 05-27-2005 10:47 PM
