CCV hose goes where? - JeepForum.com
post #1 of 9 Old 06-01-2016, 09:47 PM Thread Starter
Ryan_Colorado
Ok, I'll hopefully name all these right. The air inlet hose attached to the front PCV elbow is presently just dangling down unattached. It was this way when I bought it. Where is it supposed to be connected to? There appears to be a taped-off inlet in the back of the airbox. Is that where this hose is supposed to go?
The grommets and elbows (front and back) appear to be leaking. There's also oil in the airbox that I know fixing has been covered elsewhere on here. Figuring out this hose is step one.
Thanks!
Ryan_Colorado is offline
post #2 of 9 Old 06-01-2016, 10:18 PM
ou2mame
What year?
Sent from my HTC M9 using Tapatalk
ou2mame is offline
post #3 of 9 Old 06-01-2016, 10:35 PM
shooptube
Big Brother
shooptube's Avatar
1997 XJ Cherokee
Originally Posted by Luke95 View Post
I am Moar low.
Build Thread:
Instagram:
shooptube is offline
post #4 of 9 Old 06-02-2016, 08:51 AM
axlaxl
Check out this pic and the thread below for info on the 4.0 PCV/CCV. Should answer most if not all of your questions. Make sure you have the proper elbows for the front and rear as they have different flow rates.
https://www.jeepforum.com/forum/f11/c...-flow-2829394/
axlaxl is offline
post #5 of 9 Old 06-03-2016, 11:42 AM Thread Starter
Ryan_Colorado
Mine is a '90. I'll check if there's a inlet on the box in that spot. I think the one in back that's covered in tape is on the lower portion of the box (below the air filter)? This diagram appears to connect above it. Hmm. I'll get back to you. Thanks!
post #6 of 9 Old 06-05-2016, 02:23 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here:
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #7 of 9 Old 06-05-2016, 02:24 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This could be helpful also:
http://cruiser54.com/?p=121
post #8 of 9 Old 06-06-2016, 01:13 PM Thread Starter
Ryan_Colorado
Hey, that's really helpful, thanks! I see it is supposed to go to the inlet in the back of the box. Any idea why it might be disconnected?
This guy made some changes. Something with the coolant lines also that I'll take a pic of sometime.
post #9 of 9 Old 06-06-2016, 02:09 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Who knows. Maybe too cheap to replace them?
Let's see photos of the coolant lines.
