Cant remove key - JeepForum.com
post #1 of 6 Old 02-28-2009, 09:19 PM Thread Starter
Sanguinea
Cant remove key
I just bought a 89 jeep cherokee with a right hand drive conversion (for delivering mail) and I drove it 5 hours on the interstate to get it home only to find that I couldn't remove the key from the ignition (stock column and ignition). It doesnt seem to be turning all the way back to the point where you could remove it and the previous owner didnt seem to have any problems removing nor did I when I test drove it. Am I missing something or do I need to spend the $10 to replace the ignition lock cylinder. Thanks
2000 XJ, 3'' lift/ 31" BFG AT/ DIY Winch Bumper/ DIY rockrails/ DIY roofrack/ DIY lightbar
90% driver, 10% Jeep..... I need a bigger Jeep
Sanguinea is offline
post #2 of 6 Old 02-28-2009, 09:21 PM
scoot08
scoot08's Avatar
mine does that sometimes, i just hit the shifter forward and it turns back enough to come out
scoot08 is offline
post #3 of 6 Old 02-28-2009, 09:23 PM
austin6137
austin6137's Avatar
1990 XJ Cherokee
is it in park all the way the key wont come out, unless it egages right in park. if not try pushing in on the key
and turning it.
all i can think of
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #4 of 6 Old 02-28-2009, 09:29 PM Thread Starter
Sanguinea
Thanks buddy, that did it. Thats why I ask here.
post #5 of 6 Old 02-28-2009, 10:09 PM
scoot08
scoot08's Avatar
anytime. i dont know how to fix it but its not really that big of a problem
scoot08 is offline
post #6 of 6 Old 06-19-2009, 04:48 PM
majmjjen
my fix
I have a 97 xj, I just hold the shifter button in and turn the key switch. Found it by accident.
majmjjen is offline
remove AC modok XJ Cherokee Technical Forum 12 02-26-2010 05:47 PM
What to remove?? UltimatE XJ Cherokee Technical Forum 19 03-12-2006 03:02 PM
Which bolts to remove to remove leaf packs? 00xj54 XJ Cherokee Technical Forum 13 01-18-2006 01:18 AM
I Cant Remove The Rad!!! Help 2tone93zj XJ Cherokee Technical Forum 6 10-30-2005 02:38 PM
What to use to remove sap? Scootr XJ Cherokee Technical Forum 12 11-01-2004 09:52 PM
