Can't find replacement PCV valve - JeepForum.com
post #1 of 5 Old 02-20-2009, 08:17 PM Thread Starter
tallyjeepguy
Guest
My PCV valve (outflow) is cracked and I can't find a replacement anywhere. I have a '92 XJ, 4.0L , anyone know of a suitable replacement?
tallyjeepguy is offline
post #2 of 5 Old 02-20-2009, 08:20 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You don't have a PCV valve. It's just an open elbow and teamcherokee.com has them along with the grommits and lines. The XJ uses a ccv system, Taking in clean air from the airbox in the front, and putting unburned elements back through the intake on the rear side. If your rear line becomes clogged it will cause oil to be pushed into the air filter.
xjfever is offline
post #3 of 5 Old 02-20-2009, 08:21 PM
warrior_oh58d
1991 XJ Cherokee
the 4.0 has a CCV system, not PCV...meaning there isn't a checkvalve or anything its just an open tube. i'd look at the junkyards....it may be on the rack with the pcv valves at the autoparts store as a breather tube
warrior_oh58d is offline
post #4 of 5 Old 02-20-2009, 08:24 PM Thread Starter
tallyjeepguy
Guest
that would explain it. I didn't know there was a difference between PCV and CCV. Thanks.
post #5 of 5 Old 02-20-2009, 08:26 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Yeah, the autoparts have them, but I couldn't find one that was the correct size, so I went to the dealer and bought all of it new( grommits, elbows, and lines). Wasn't terribly expensive, but teamcherokee has it all cheaper. I never find the deals till after I buy something.
xjfever is offline
heater valve replacement help? mikewitdaspike XJ Cherokee Technical Forum 10 01-03-2009 04:18 PM
Valve stem replacement black2door XJ Cherokee Technical Forum 2 05-16-2007 06:29 AM
Can't find EGR valve JohnnyWamp42 XJ Cherokee Technical Forum 3 11-28-2005 03:42 PM
Valve Cover Replacement Parts... 95XJSport XJ Cherokee Technical Forum 5 11-23-2005 12:41 PM
Heater vacuum valve - where to find? torble XJ Cherokee Technical Forum 2 09-05-2004 09:56 AM
