Block drain petcock? - JeepForum.com
 1Likes
  • 1 Post By Wyo
post #1 of 8 Old 08-02-2021, 01:50 PM Thread Starter
mynameisrose
mynameisrose's Avatar
Hey all. Has anyone installed a brass petcock in the block coolant plug hole for easy and clean flushes?
mynameisrose is offline
post #2 of 8 Old 08-02-2021, 04:22 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You can if you want, but having owned 8 XJ's over the last 19 years, I never found one to be necessary. I also never use the radiator drain valve, it is too fragile.
I always drain the cooling system by removing the lower radiator hose.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 8 Old 08-03-2021, 12:37 PM
Wyo
Wyo's Avatar
If you want, the easy way is to get what in the plumbing industry is known as a dishwasher ell, or elbow.
It is 3/8th NPT (For the block end) and a tight 90 that is 3/8th Flare.. Orient with the 90 facing down.
Then get a 3/8 Flare Cap. this is easy to remove with a socket but seals very well.
Fourspeedman likes this.
Wyo is offline
post #4 of 8 Old 08-04-2021, 04:07 PM Thread Starter
mynameisrose
Nice. A 90 out of the block that I can stick a hose on and run into a bucket is just what I was thinking. Thanks for that. I was wondering about the thread pitch too, however I've read on other forums that the thread could also be 5/8 sae or 1/4 npt depending on block casting. I have a 94 so hopefully I can find the right one, or maybe I'll get all three before I do it and have my bases covered.
post #5 of 8 Old 08-04-2021, 08:42 PM
Wyo
Wyo's Avatar
Well I guess I am dated cause I looked up a dishwasher ell and they now use a garden hose adapter and go to 3/8" compression fitting......... I suppose so a home owner doesn't need a Flaring tool and wrenches to install.
Back in the day the water inlet valve was 3/8 NPT and you used copper pipe and a flair to hook them up.
So What you want............... 3/8 NPT X 3/8" Flair adapter ell. and a 3/8" Flair cap.
https://images-na.ssl-images-amazon....L._SL1125_.jpg
https://www.ebay.com/itm/16461260572...sAAOSwFj5f6ohW
Wyo is offline
post #6 of 8 Old 08-05-2021, 01:52 PM Thread Starter
mynameisrose
I saw that too. A street elbow with a petcock would probably work as well. I'll get something figured out with a handful of fittings. I would have liked a petcock in the lower rad hose but it's such a tight angle in there and changes size from 1-1/2 to 1-1/4.
post #7 of 8 Old 08-05-2021, 05:06 PM
Wyo
Wyo's Avatar
The only reason for a petcock back in the day was because you used water and you drained the engine frequently (Daily) for freeze protection and rust issues/
You will drain every 2-3 years and the 90 will pee straight down to the container but you can still fit a piece of 1/2" ID garden hose over the threads if you want.
Wyo is offline
post #8 of 8 Old 08-11-2021, 11:07 AM
BorkaBork
I used the brass petcock off a Volvo 240 redblock motor, fits perfectly and works much better. Has a hose-fitting end so no mess.
BorkaBork is offline
