Blew a head - JeepForum.com
 1Likes
  • 1 Post By S8NNG8
post #1 of 4 Old 06-19-2019, 12:14 AM Thread Starter
Enuminada
Xj Blew a head
Thats were it started, im encountering a 9v batt gauge, after having replaced the head, and gasket and such. New belt is squealing loud. voltage wasnt dropping before the rebuild, so it dies after running for a bit. new plugs installed and got its timing in place via bringing cylinder one tdc, and aligning the roller cap. unsure about the belt being the culprit as i have it rather tight, just needing guidance as i bought this off of a friend knowing i could fix. its been a roller coaster. hoping i just need to tighten the tensioner more, but its holding a charge problem is weird... 99 xj.
Enuminada is offline
post #2 of 4 Old 06-19-2019, 08:09 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
My ZJ 4.0 was recently having voltage issues. Tightened the belt till the squeal stopped and no more problem.
D3<!L!>3D
S8NNG8 is offline
post #3 of 4 Old 06-19-2019, 06:44 PM Thread Starter
Enuminada
That fixed the voltage error but now it stalls out and the code p1391 is thrown and dies when put into gear... the crank position sensor is new so im back on the coster, while idling its does well but still does bog out.
post #4 of 4 Old 06-19-2019, 10:06 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Don't doubt the possibility of parts being bad right out of the box. These days it should be the first thing to suspect.
TheBoogieman likes this.
D3<!L!>3D
S8NNG8 is offline
