Bigger Oil filter whats the point? - Page 3 - JeepForum.com
post #31 of 42 Old 10-05-2006, 10:08 AM
WMW0505
Originally Posted by hemihead9
I have one, It was purchased for my Hemi, but ALL Chrysler and Ford filters are the same. 3/4-16 thread and the gasket size also. They differ slightly in diameter
and length. The Wix filter is about 7 inches long, I think it will fit.
idk about that...my powerstroke's filter is a lot bigger than my XJ filter...in dia.
WMW0505 is offline
post #32 of 42 Old 10-05-2006, 10:17 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Originally Posted by TheArsonist21
Anyone know what the fram part number is?
Look about 10 posts up from yours. Just in case you can't, it is PH8A. I've used Fram filters for almost 20 years now and never had a problem, but recently, I've switched to K&N Golds. They're well worth the extra few bucks. They're pretty stout and seem to be oversized a little from the standard 8A sized filters.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #33 of 42 Old 10-05-2006, 10:18 AM
hemihead9
Let me restate that, most 6 and v-8 filters for ford and chrysler are the same. I have a master catalog from WIX and when I compared most specs are the same,
except length and diameter. Not diesel.
hemihead9 is offline
post #34 of 42 Old 10-05-2006, 12:31 PM
Erik S.
Guest
If you want a 2 quart filter Wix 51773 are you excited now. As long as it clears it is the same filter only longer
Yeah, for an extra 1.5 quarts, I'd start to get excited and interested.
Erik S. is offline
post #35 of 42 Old 10-05-2006, 12:33 PM
Erik S.
Guest
Originally Posted by WMW0505
lol...effort? there is no more effort involved in running an oversized filter compared to stock. all you do is ask for a diff filter.
the way I and someone else read it, you have to change to the standard threads, so there is some effort.
If that isn't true, and all you have to do is buy a larger filter, then you're correct, there is no extra effort.
Erik S. is offline
post #36 of 42 Old 10-05-2006, 12:43 PM
96XJTech
Guest
I run a Mobil 1 ML-301 Over-Sized Filter with Synthetic Oil, with a change interval of every 5,000 miles, and haven't had any problems. For mine, it screwed right on, and I didn't have to do any modifications to the threads. As long as your oil filter is positioned horizontally, no modifications should be necessary to run the larger filter.
96XJTech is offline
post #37 of 42 Old 10-05-2006, 03:43 PM
Car RamRod
if you guys want the number for a 5.0l mustang filter, the motorcraft is the FL1-A.
I use a motorcraft over anything else in my car.
1986 Comanche, 4x4, 2.8l v6
1989 Mustang LX Coupe, h/c/i, bolt ons, 5lug
have to break in engine and trans, then hitting E-town and a dyno
Car RamRod is offline
post #38 of 42 Old 10-07-2006, 03:15 PM
Jmila1901
Jmila1901's Avatar
I just put the larger filter in... Dont know how on gods good earth i am going to get it out next time i need to change the oil lol...
Justin Mila
1993 Country XJ- AW4, 4.0 HO, Chy 8.25, Homebrew K&N Intake... DailyDriver
2002 Laredo WJ- Broken Bumper Mod... Weekend Toy
2007 Nike Dunks Size 12... Backup
Blue Jeep Club Member # 221
Originally Posted by KeepRockin024
You know your drunk when you have a little to much blood in your alcohol stream
Jmila1901 is offline
post #39 of 42 Old 10-07-2006, 03:51 PM
BigBearXJ
^^ Is yours horizontal or vertical?
Eat, Jeep and be Merry.
BigBearXJ is offline
post #40 of 42 Old 10-07-2006, 04:08 PM
Jmila1901
Jmila1901's Avatar
Horizontal
Justin Mila
post #41 of 42 Old 10-07-2006, 04:25 PM
xj-xile
xj-xile's Avatar
The linked writeup (link in 2nd post in the thread) says in the 5th paragraph: "The following write-up deals primarily with the earlier non-HO engines ('87 to '90) who had the metric oil filter mounted vertically." Ergo, the larger filter option applies to most XJs.
The same writeup is useful for the all-too-common problem of leaking O-rings at the filter adapter.
Personally, I like the larger filter because it is easier to handle. It won't slip past the starter if I drop it while trying to install it. Sometimes I deliberately rest it on the starter before I pick it up and screw it on, and all the wiring & other parts of the Jeep keep it from getting away from me.
xj-xile is offline
post #42 of 42 Old 10-07-2006, 04:41 PM
jharte
Just chainged my oil. Fram PH8. No problems. Of course, while under there, I did notice I cracked my exhaust header.......
I hate it when I'm doing a cheap simple job and find something expensive I have to fix!
Must be the gravel and dirt roads I drive. Oh well.
JH
jharte is offline
Whats going on? ľ" 12 point c-clip removal sprintagogo XJ Cherokee Technical Forum 1 12-07-2007 12:50 PM
Changing oil and want use bigger filter Schmeidler XJ Cherokee Technical Forum 5 06-14-2007 10:57 PM
ULTIMATE LONG ARM SUSPENSION whats good, whats not AllXJ96 XJ Cherokee Technical Forum 38 01-26-2006 08:59 AM
bigger calipers need bigger rims... myth or reality? twisted_ed XJ Cherokee Technical Forum 5 01-27-2005 11:25 AM
Bigger oil filter balloo93 XJ Cherokee Technical Forum 32 01-26-2004 05:37 PM
