Bigger Oil filter whats the point? - JeepForum.com
post #1 of 42 Old 10-04-2006, 08:15 AM Thread Starter
blackgnx
1997 XJ Cherokee
Just wondering i'm getting ready to change the oil. I hear all this talk about bigger oil filter. I know you get more oil. But don't you run lower oil pressure that way too? Whats the real reason you all put a 5.0 filters on a XJ 4.0L. BYW whats the part numbers too just in case i hear enough good reason for it. . in Delco or Purlator please? Also how can i post my pictures, i tried but no luck.
blackgnx is offline
post #2 of 42 Old 10-04-2006, 08:22 AM
mjaybird65
there's a link in the Tech sticky for this
http://www.madxj.com/MADXJ/technical...Conversion.htm
2001 Black XJ Sport 4x4
4.0L I6, AW4, NP231, 8.25 rear
mjaybird65 is offline
post #3 of 42 Old 10-04-2006, 08:23 AM
Ivanito
Ivanito's Avatar
You won't get a pressure loss from running a larger filter (unless of course you only put in the amount of oil that the book states). Larger oil filter will also give you more filtration due to more filtering media in the oil filter (that is a lot of filtering).
Ivanito is offline
post #4 of 42 Old 10-04-2006, 08:33 AM
WMW0505
just the advantage of having more oil...on angles its a little more peace of mind and it also spreads the amount of particles that may be in your oil over a larger volume...and like said above...more filter area. and why not? as far as i know of there are no disadvantages...the filter was cheaper for me and more oil is better, more filter area is better...and there will be no loss of oil pressure if you put the propper amount of oil back in it...you just have to add the extra amount of oil that the bigger filter holds compared to the stock one. so until i hear something bad about it im gonna keep on runnin my oversized filter.
-Willie
WMW0505 is offline
post #5 of 42 Old 10-04-2006, 08:52 AM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
more oil, more filtration area. What's not to like? I run our Jeeps on synth oil at 5k mile intervals, so the extra bit of oil and larger filter are nice to have.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #6 of 42 Old 10-04-2006, 09:33 AM
trailblaze
trailblaze's Avatar
so basically just buy the filter for any yr mustang with a 5.0 engine in it?
Matt
trailblaze is offline
post #7 of 42 Old 10-04-2006, 09:35 AM
gregmondro
gregmondro's Avatar
go look for one for a 93
the filter is the same between the 5.0l and the 4 cylinder mustang for that year (93)
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #8 of 42 Old 10-04-2006, 09:40 AM
Vendor
1995 XJ Cherokee
I know that the Mobil pn is M1-301. I think the K&N Gold pn is like HP3001 or something to that effect. Same filter as for a Ford F150 truck V8. Maybe it's the same as the Mustand V8 filter too...
Jason West -
post #9 of 42 Old 10-04-2006, 09:40 AM
Chuck Cook
Guest
Hopefully you can cross reference the filter from the Mobil 301. I got the Mobil 301 at Checker, a few more bucks, hopefully a quality filter. And for you, it is a direct screw on, no adaptor needed. If you starter does not a have plastic or rubber flap protecting the electrical connections, be sure you don't bridge the connections by accident while installing the larger filter. Chuck
Chuck Cook is offline
post #10 of 42 Old 10-04-2006, 11:04 AM
Ivanito
Ivanito's Avatar
Ivanito is offline
post #11 of 42 Old 10-04-2006, 12:03 PM
PMAZ7
Guest
Not that it would increase things that much, but a larger filter would also mean the greater the chances of the oil running cooler. Oil filters have such a thin wall on them that they really do dissapate temp well.
PMAZ7 is offline
post #12 of 42 Old 10-04-2006, 12:11 PM
WMW0505
the Wix number is 51515 i think...correct me if im wrong.
WMW0505 is offline
post #13 of 42 Old 10-04-2006, 04:40 PM
Mee_Too
WIX #51515 is the filter I use on my '88 Grand Marquis with the 5.0 (I use WIX filters on all of my vehicles)...
Mee_Too is offline
post #14 of 42 Old 10-04-2006, 04:59 PM
Erik S.
Guest
So let me get this right? You guys are excited about an extra 1/2 quart of oil. So you all are now putting 6.5 quarts in your 4.0L?
The extra filtration, it's a benefit, but not worth getting giddy about.
Erik S. is offline
post #15 of 42 Old 10-04-2006, 05:00 PM
PMAZ7
Guest
I'd have to agree.
PMAZ7 is offline
Whats going on? ľ" 12 point c-clip removal sprintagogo XJ Cherokee Technical Forum 1 12-07-2007 12:50 PM
Changing oil and want use bigger filter Schmeidler XJ Cherokee Technical Forum 5 06-14-2007 10:57 PM
ULTIMATE LONG ARM SUSPENSION whats good, whats not AllXJ96 XJ Cherokee Technical Forum 38 01-26-2006 08:59 AM
bigger calipers need bigger rims... myth or reality? twisted_ed XJ Cherokee Technical Forum 5 01-27-2005 11:25 AM
Bigger oil filter balloo93 XJ Cherokee Technical Forum 32 01-26-2004 05:37 PM
