BDS 4.5" LA vs Clayton 4.5" LA - JeepForum.com
post #1 of 1 Old 05-25-2021, 01:04 AM Thread Starter
jameshatchxj
I am looking to build a daily driver/weekend XJ. My ideal lift is 4.5 inches with 33-inch tires and I value reliability above all else. I am currently torn between the BDS 4.5 inch long arm kit and the Clayton Offroad 4.5 inch long arm. For the BDS, I plan on going with FOX 2.0 shocks and for the Clayton offroad, I plan on putting bilsteins in. As I see it, the Clayton has the advantage of a three-piece crossmember for easy transmission access as well as better bushings that can be bought at more autoparts stores. However, it also seems to use a radius arm set up (correct me if I am wrong), and this seems to be detrimental to strength and offroad performance. The BDS kit seems to have the advantage of a true 4 link setup and therefore better strength characteristics. Finally, BDS being a bigger company seems to be at less of a risk of going under and a better chance at being around when I eventually need to warranty parts out when compared to the smaller company that is Clayton's Offroad. Which kit would you guys recommended given all this information?
Thank you
jameshatchxj is offline
