Battery for '89 Cherokee needed - JeepForum.com
post #1 of 14 Old 08-17-2019, 03:29 PM Thread Starter
Gremmy
1989 XJ Cherokee
Hi, what battery Ah are you running and is best for 1989 4 L petrol auto. Thanks.
Gremmy is offline
post #2 of 14 Old 08-17-2019, 04:10 PM
2oldjeeps
over the years when i need a battery i get the biggest that will fit in the space and $ that fit my wallet. its not a big deal.
ex. ,hummer guys get real fussy about special batteries so i posted a pix of mine with my lawn tractor battery running it! started just fine...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #3 of 14 Old 08-17-2019, 09:07 PM Thread Starter
Gremmy
1989 XJ Cherokee
Thanks good to know... the Jeep has many gremlins and I need every amp or do I? Cranking the engine is laboured, idle is too slow, occasional severe misfires and the gearbox drops gear every 12 months. Also have to reach into the cowl to push the rod to select dip-main headlights.
Gremmy is offline
post #4 of 14 Old 08-18-2019, 07:04 AM Thread Starter
Gremmy
1989 XJ Cherokee
I cannot find the correct Ah number for battery for '89 4 litre petrol. What is the correct Ah? Thanks.
Gremmy is offline
post #5 of 14 Old 08-18-2019, 08:26 AM
Saudade
1988 XJ Cherokee
You can simply look it up on any autoparts website, like Autozone, Napa or O'Reilly. My 88 is a group size 58. 550 CCA is pretty standard. You can find batteries with more and less.
Saudade is offline
post #6 of 14 Old 08-18-2019, 09:21 AM
2oldjeeps
fix the rest,batt will be fine
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #7 of 14 Old 08-18-2019, 11:31 AM Thread Starter
Gremmy
1989 XJ Cherokee
Thanks!
Gremmy is offline
post #8 of 14 Old 08-18-2019, 11:32 AM Thread Starter
Gremmy
1989 XJ Cherokee
Thanks. Anyone so how to increase idle, 350 at moment.
Gremmy is offline
post #9 of 14 Old 08-18-2019, 05:44 PM
JWELK
Go to Walmart, look on the computer, choose the closest one that fits, put it in your cart pay and walk out. If you go to a super center, they will do all of the above except pay for it
JWELK is offline
post #10 of 14 Old 08-18-2019, 06:26 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have you ever visited my website? You need to complete Tips 1,3,4, 5 and 10!!
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #11 of 14 Old 08-18-2019, 09:58 PM
JWELK
Thanx, while I don't have one of that vintage, some interesting topics. What happened to the one on reducing wind noise? I've started installing sound deadening in the doors, tailgate and rear compartment panels. I've only done the rear panels and the driver side rear door. Can't tell much so far.
The engine compartment would be a big help, but I'm afraid it will cause it to heat up even more.
According to a sound app on Android, I'm running 50-60 db. Windows shut, A/C, radio, and S.O., off.
JWELK is offline
post #12 of 14 Old 08-18-2019, 10:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I never did that one because the part needed is NLA.
Since you have a 99, you should already have that part.
And, you should have the better A pillar wind deflectors.
post #13 of 14 Old 09-17-2019, 05:58 PM Thread Starter
Gremmy
1989 XJ Cherokee
I got a battery for 1989 4 litre auto in the post, it was supposed to fit. Did too once I stretched the negative cable and wedged a foam brick on top. Only half inch from the hood. I did have some extra long battery retaining fixings but they got lost years ago.
Gremmy is offline
post #14 of 14 Old 09-17-2019, 09:39 PM
BagusJeep
BagusJeep's Avatar
1981 CJ7
An I6 turns over real easy so you do not need a lot. If you are in a cold zone then allow one CCA for every cubic inch of engine displacement, about 250 Amp CCA is sufficient for a working 4.0. If you got twice as much, even better. Cherokees run hot under the hood (I can barely open it on a hot day) and the heat will kill the battery faster than in other jeeps, they are hard pressed. the chemical reactions take place faster with heat (high school stuff) but this shortens the working life. An expensive battery versus regular change of cheaper battery, I would take the latter.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
