Which battery - JeepForum.com
 1Likes
  • 1 Post By 2oldjeeps
post #1 of 6 Old 11-09-2019, 07:39 AM Thread Starter
green199newbee
Which battery
Good morning
I have a 1999 XJ 4.0 and am going to put a winch on the jeep. My battery is fine but have been told the winch will kill an average battery when it is time to use it. Truth??? What batteries are you running. I am on a tight budget and really do not want to spend $250 for a unnecessary large CCA battery if not necessary! Thanks ahead of time?
green199newbee is offline
post #2 of 6 Old 11-09-2019, 04:58 PM
rjbruzan
Most likely a group 34. I prefer an AGM because its totally sealed and wont leak acid. One of the best out there is NorthStar. About $250 from Batteries plus with a discount if you order it ahead. The one in my TJ is 8 years old and going strong. I bought a new one for it and current one will go in my daily driver WJ.
My XJ beach truck has a less expensive Duration brand AGM (about $160 at Farm and Fleet) thats 7 years old and strong as when new.
XJ and TJ have winches that get used/abused.
Ron
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 6 Old 11-09-2019, 11:40 PM
2oldjeeps
i would do step one,add the winch and mess with it.
see how that goes b4 any battery work...probably need nothing else.
JWELK likes this.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #4 of 6 Old 11-12-2019, 10:42 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
Lead acid batteries are not designed to go full or near full discharge and life span can take a big toll if they do. Deep cycle AGMs on the other hand won't care. I have Odysseys on both Jeeps. Don't think you'll find many brands with twice the crank power and 4 year full replacement out there.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
rep-tile is offline
post #5 of 6 Old 11-18-2019, 08:35 PM
cpttuna
Set your 99 up for extended idle. this will also help
cpttuna is offline
post #6 of 6 Old 11-18-2019, 09:16 PM
RevScott
Originally Posted by green199newbee View Post
Good morning
A damn good battery Isolator, a continuous duty solenoid, with a dash switch and a second full sized battery that matches your primary. Your Winch gets hooked to the secondary battery, a heavy welding cable goes between the positive posts of the batteries, the solenoid gets spliced into this cable with the on off switch dash mounted and the heavy duty battery isolator mounted between the two batteries and the alternator. Your primary bat will always stay charged, as will the secondary your winch will NEVER drain the primary unless you flip the dash switch on, energizing the solenoid for extra power. This will also allow you to jumpstart yourself with the aux (secondary battery) providing everything is wired properly. Ive been running a setup identical to this for decades, with the addition of a plug in jumper cable with the socket mounted in the grill. Just plug my vehicles end of the cables into the socket and the clamps are on the other end. The plug/sockets are identical to those used to recharge electric forklifts and are available at most industrial supply stores. The clamps and cables are cheapest by buyinga good set of jumper cables, and cutting one set of clamps off. One other thing, since the battery isolator is made of two LARGE Diodes that prevent current from flowing back into the alternator, this will protect your electrical system from damage by jumpstarting other vehicles as well as spikes generated by stalling out a winch.
RevScott is offline
