Backspacing??? - JeepForum.com
post #1 of 4 Old 01-11-2008, 02:33 PM Thread Starter
94HOCHEROKEE
1994 XJ Cherokee
Backspacing???
Well I just got some 15x7 Black Steel rims w/ 31x10.50R15 General Grabber AT2 tires, and I noticed that the tires don't sit centered in th fenderwell. I think I have stock backspacing but i don't know, can you change the backspacing? Or does it come in the rim?? Any feed back is appreciated. Thanks
94HOCHEROKEE is offline
post #2 of 4 Old 01-11-2008, 02:37 PM
1996xj
1996xj's Avatar
2005 WK
Backspaicng it how far the mounting place is molded from the inside edge of the rim. I believe stock BS is 5in, if you want them to stick out go with something like 4in BS.
The only way to change The space between your hubs and rim is with wheel spacers, which most ppl dont recommend.
1996xj
3" Rough Country Lift, 3in shackles, 3 RC shocks, 31" BFG ATs, 2 KCs, Lighted Roofrack, Soft 8s, TC drop, Custom oil leak deflector.
If only i could get a set of tires to last me 10,000Miles
Originally Posted by toates89
i am just gunna drive around in 4lo on dry streets, and peel out
Originally Posted by 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket.
1996xj is offline
post #3 of 4 Old 01-11-2008, 02:38 PM
rstarch345
Stock is 5 1/4" BS and aftermarket are generally 4-4.5" BS. You can decrease BS with spacers, but you can't increase it without get new wheels (or cutting down the axle).
2K XJ - 6" lift w/ 34s
'98 XJ Laredo - Stock (and staying that way)
'71 M151
I'm a proud member of
rstarch345 is offline
post #4 of 4 Old 01-11-2008, 03:46 PM Thread Starter
94HOCHEROKEE
1994 XJ Cherokee
Nice. Thanks for the input.
what is backspacing? Tybombero XJ Cherokee Technical Forum 17 11-27-2007 10:47 PM
need help on backspacing 90XJGuy XJ Cherokee Technical Forum 10 06-24-2005 02:12 AM
Need to know all about backspacing Jeepernick XJ Cherokee Technical Forum 6 06-11-2005 04:35 AM
Backspacing XtremeJeep XJ Cherokee Technical Forum 11 04-07-2005 01:01 PM
Backspacing fdsa4877 XJ Cherokee Technical Forum 2 03-22-2005 07:44 PM
